List of TSBs
Old Aug 7, 2008 | 06:14 PM
wreedKR's Avatar
List of TSBs
Anyone know where a free list of TSBs are for a 07 F150?
Old Aug 7, 2008 | 11:13 PM
projectSHO89's Avatar
Try at www.alldatadiy.com for a listing of TSB titles
Old Aug 7, 2008 | 11:20 PM
Paralyzer's Avatar
Technical Service Bulletins
2007 F-150 - Canada (English)
08-14-6
HARLEY-DAVIDSON SUPERCHARGER / EXHAUST CATALYST RATTLE
08-14-3
5.4L 3V / 4R75E ONLY - BUILT BETWEEN 12/4/2006 TO 5/20/2008 - ENGINE RPM FLARE DURING 3-4 UPSHIFT UNDER LIGHT THROTTLE ONLY
08-12-9
INOPERATIVE RKE TRANSMITTER (KEY FOB) - DISCHARGED KEY FOB BATTERY
08-12-1
5.4L ENGINE ONLY - MIL ON WITH DTCS P0301 AND P0171 - EXTENDED IDLE ONLY - BUILT ON OR BEFORE 5/20/2008
08-11-1
INTERMITTENT VEHICLE VIBRATION - PARKING BRAKE DISENGAGEMENT CONCERNS
08-8-9
GRINDING NOISE FROM CLIMATE CONTROL - CHANGING AIR DISTRIBUTION MODES - BUILT AFTER 11/29/2005
08-7-6
SPARK PLUG REMOVAL INSTRUCTIONS - 4.6L 3V/5.4L 3V/6.8L 3V
08-4-4
COLD START ROUGH RUNNING/HESITATION/BACKFIRE - 4.6 ONLY
08-4-3
MALFUNCTION INDICATOR LAMP (MIL) ON WITH DIAGNOSTIC TROUBLE CODE (DTC) - P0456
08-4-2
COLD START FEAD HOOT - WHISTLE NOISE / BUILT BEFORE 1/28/2008
08-2-9
ERRATIC FUEL GAUGE OPERATION - MIL ON - DTCS P0460/P0463 OR INSTRUMENT CLUSTER MODULE DTC B1201 - VEHICLES BUILT BEFORE 12/3/2007
08-1-4
WATER LEAK - ROOF OPENING PANEL DURING HIGH PRESSURE CAR WASH
07-25-13
FRAME REPLACEMENT MATRIX - SERVICE TIP
07-25-2
TAILGATE STRIKER - NOISE/RATTLE
07-24-8
ENGINE MISFIRE DURING CRUISE WITH OR WITHOUT DTCS (MEXICO ONLY)
07-24-7
A/C COMPRESSOR SHUTOFF - HIGH AMBIENT TEMPERATURES - VEHICLE STATIONARY IN GEAR
07-24-5
DRIVERS SIDE COWL PANEL POPPED-UP - BUILT BEFORE 11/12/2007
07-24-3
COLD START ROUGH RUNNING/HESITATION/BACKFIRE - 5.4L ONLY
07-22-7
PAINT - INSTRUMENT PANEL - SCRATCH/MAR REPAIR TIPS
07-21-3
HIGH PRESSURE POWER STEERING LINE SEEPAGE - COLD CLIMATES ONLY (EXCLUDING HERITAGE F-150)
07-21-2
4.6L 2V, 5.4L 2V, OR 6.8L 2V - SPARK PLUG THREAD REPAIR PROCEDURE - NOT COVERED UNDER NEW VEHICLE LIMITED WARRANTY
07-16-17
SPARK KNOCK UNDER LIGHT LOAD AND ACCELERATION - 3.8L, 3.9L, AND 4.2L - SPLIT PORT INTAKE MANIFOLD RUNNER CONTROL (IMRC)
07-16-13
WRENCH LAMP ON - DTC P0731 - 4.2L AND 4R75E ONLY
07-12-3
RCM FAULT REPORTING USING DTCS AND BIT-MAPPED PARAMETER IDENTIFIERS (PIDS) - SERVICE TIPS
07-12-1
POWER SLIDING REAR WINDOW MOTOR REPLACEMENT
07-10-9
VIBRATION FROM THE DRIVELINE AT HIGHWAY SPEEDS
07-10-8
STEERING WHEEL VIBRATION AT 50 MPH (80 KM/H) OR HIGHER - STEERING WHEEL NIBBLE AT 65 MPH (105 KM/H) OR HIGHER
07-6-5
LOBO - REAR AXLE TUBE FRACTURE AT CENTRE CARRIER (MEXICO ONLY)
07-5-8
BATTERY SERVICE - OPERATION OF BATTERY EYE - CHARGING SERVICE TIPS
07-4-5
VIBRATION DIAGNOSIS - TIRE/WHEEL RUNOUT
07-4-3
LEATHER-WRAPPED STEERING WHEEL - LEATHER COMING LOOSE
07-2-6
POWER WINDOW SLOW UPWARD TRAVEL
07-1-7
MERCON® ATF REPLACED BY MERCON® V AS A SERVICE FLUID FOR SOME POWER STEERING SYSTEMS
06-26-1
MERCON ATF IS BEING REPLACED BY MERCON V AS A SERVICE FLUID FOR SOME MANUAL TRANSMISSIONS
06-25-15
ALUMINUM BODY PANELS - CORROSION - SERVICE TIP
06-25-5
4.2L HIGH IDLE - INITIAL START UP
06-25-3
PIONEER NAVIGATION RADIO - SEEK FUNCTION INOPERATIVE - SERVICE TIP
06-23-6
NOISE FROM BACK GLASS - POWER SLIDING REAR WINDOW ONLY
06-21-19
HEATER CORE LEAKAGE AND ELECTROLYSIS (INFORMATION ONLY)
06-21-7
AUDIO / NAVIGATION SERVICE AND ORDERING PROCEDURES
06-19-16
SHUDDER/VIBRATION ON MODERATE TO HARD ACCELERATION
06-18-15
IGNITION DIAGNOSTICS
06-17-8
SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS
________________
TSBs found:43
Old Aug 7, 2008 | 11:21 PM
Paralyzer's Avatar
if you need more info on any of them let me know.
wreedKR's Avatar
Can you send me this one?
07-24-7
07-24-5
Old Aug 7, 2008 | 11:26 PM
Paralyzer's Avatar
FORD: 2007-2008 F-150, F-150
LINCOLN: 2007-2008 Mark LT
ISSUE:
Some 2007-2008 Mark LT and F-150 vehicles equipped with 5.4L or 4.6L engine only, may exhibit a loss of A/C compressor operation in ambient temperatures greater than 110 °F (43 °C), when the vehicle is stationary for periods longer than 15 minutes, with the transmission in gear. Idling in gear and extreme ambient temperatures may cause the vehicle control systems to disable A/C compressor operation.
ACTION:
Follow the Service Procedure steps to replace the A/C compressor pulley and coolant pump pulley.
SERVICE PROCEDURE
NOTE: THIS TSB IS INTENDED TO RESTORE A/C COMPRESSOR OPERATION IN EXTREME HIGH AMBIENT TEMPERATURES WHEN THE TRANSMISSION IS PLACED IN THE PARK POSITION. DO NOT ATTEMPT TO ADDRESS CUSTOMER CONCERNS OF GENERAL A/C TEMPERATURE OUTPUT PERFORMANCE WITH THIS TSB. THIS TSB WILL NOT IMPROVE A/C SYSTEM DUCT TEMPERATURE OUTPUT PERFORMANCE.
NOTE: DURING EXTREME HIGH AMBIENT TEMPERATURES WHEN IDLING STATIONARY FOR EXTENDED PERIODS OF TIME IN GEAR, IT IS RECOMMENDED TO OPERATE THE A/C IN THE MAX POSITION, REDUCE BLOWER FAN SPEED FROM THE HIGHEST SETTING, AND PUT THE TRANSMISSION INTO THE PARK POSITION TO CONTINUE TO RECEIVE COOL AIR FROM THE A/C SYSTEM.
Replace the A/C compressor pulley. Follow Workshop Manual (WSM), Section 412-01 for removal and installation details.
Replace the coolant pump pulley. Follow WSM, Section 303-03 for removal and installation details.
Drain approximately 1 quart of coolant from the cooling system into a clean container which will permit reuse of coolant in the vehicle. Refer to WSM, Section 303-03.
Replace the clamp on the heater core feed hose, near the right hand front of engine, at the water pump outlet pipe connection point.
Refill the cooling system.
PART NUMBER PART NAME
F6TZ-8509-AA Coolant Pump Pulley
7C3Z-19D784-A (YB-3075) A/C Pulley
W709811-S900 Hose Clamp
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
072407A 2007-2008 F-150 4X2, 5.4L and 4.6L Engines, 2007-2008 Mark LT 4X2. Replace A/C Compressor Pulley, Coolant Pump Pulley and Heater Feed Hose Clamp at Coolant Pump Outlet. Includes Time Remove and Install A/C Compressor and to Drain and Fill Cooling system.(Do Not Use With 19700A,19700A4, 8509A,8620F, 8616A, 18472A). 1.7 Hrs.
072407B 2007-2008 F-150 4X4, 5.4L and 4.6L Engines, 2007-2008 Mark LT 4X4. Replace A/C Compressor Pulley, Coolant Pump Pulley and Heater Feed Hose Clamp at Coolant Pump Outlet. Includes Time Remove and Install A/C Compressor and to Drain and Fill Cooling system.(Do Not Use With 19700A,19700A4, 8509A,8620F, 8616A, 18472A). 1.9 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
8A616 42
Old Aug 13, 2008 | 12:32 AM
ruston3360's Avatar
plugs
i need some more info on changing the plugs on a 04 5.4. thanks if u can help
Old Aug 13, 2008 | 03:37 AM
Fifty150's Avatar
it would sure be nice to have a sticky list with links
or even better..........
a TSB forum
Old Nov 4, 2008 | 09:00 AM
Roger Wilco's Avatar
Paralyzer - can you please post details on this one? Thanks in advance.
08-2-9
