cop's and plug information
Old Aug 4, 2008 | 12:30 AM
king ranch's Avatar
just wondering if anyone had a good detailed guide on how to change cop's and plugs in a 01 5.4l
thanks
plan on getting global cops and motorcraft plugs
Old Aug 4, 2008 | 05:54 AM
jbrew's Avatar
thanks
Yea, I guess our technical articles still aren't working on this site - I'm beginning to think they were forgotten
Anyway in your other thread, I told you to look Matts link up online since ours wasn't working - just to google it. For whatever reason, you haven't. I had a little time this morning and did it for you.
Here's Matts direct link, like I said before, it's a good one -
http://www.mattstruck.com/sparkplugs/sparkplugs.html
Good Luck
Old Aug 4, 2008 | 07:05 AM
torkum's Avatar
Matt's a little heavy with the anti seize. I would leave that part out.
Old Aug 4, 2008 | 07:31 AM
BLUE20004X4's Avatar
I use anti-sieze, but just a coating, very light and it's done good so far- (knock knock on wood).
scottbigred's Avatar
thats what i was gonna ask, you guys dont like anti-seize anymore?
Old Aug 4, 2008 | 09:12 AM
KEITHHATTER's Avatar
Most don't use antisieze on the 97-03 models (I don't for 1), because, there was a problem with the plugs staying in the head.
Then Ford fixed the blow out problem with a plug that sometimes refuses to come out. 04-07 model 3v heads...
There is a wealth of info for that exact clarity on here. Just search it out...
Old Aug 4, 2008 | 04:17 PM
Fletcherhomebre's Avatar
Yeah, that's more than a little heavy! Anti-sieze - good. TOO MUCH Anti-sieze - not so good. Same goes with thread sealant, gasket sealant, thread adhesive, etc. There really is such a thing as TOO MUCH of a good thing.
Old Aug 4, 2008 | 07:46 PM
jbrew's Avatar
Yea don't use anti seize on the 97 - 02 models. These plugs don't need any help coming back out the next time. There's only 3.5 -4 threads in the chambers. Be real careful not to cross thread (use a piece of 3/8 air hose to start and run the plugs flush) the threads .
Torque = 12 -16 foot lbs.
Huh - The Ford procedure says to remove the fuel rail completely - I didn't know that.
I just remove the 4 8mm bolts/ pull the rail off the injectors/ flip it up on the Intake Manifold - it's out of the way.
Some will say leave it attached - Go ahead, you can do it - But I bet it takes you longer - You'll see.
Good Luck
Old Aug 5, 2008 | 05:11 AM
Good Luck
LOL! Could be something to do with common sense. I would bet money the techs at the stealership does it the exact same way, if they even take the rail off at all.
I know my four 6 doesn't require the rail to come off.
Old Aug 5, 2008 | 05:52 AM
jbrew's Avatar
It's a PITA with rail on IMO - Only takes 5 minutes to get out of the way - You'll spend an extra 20 minutes working around it , or more when you loose a socket.
Old Aug 5, 2008 | 09:57 AM
JMC's Avatar
JMC
25 Year Member
I unbolt the driver side rail. The regulator is in the way of #7. I use anti-seize on my plugs but I pull them out every 10k or so to look at them. Read sig for reason.
Regards
Jean Marc Chartier
PS. there is way too much anti-seize in that pic.
Old Aug 5, 2008 | 10:05 AM
jbrew's Avatar
Yea , #7's a tricky bastid with the rail on. Almost impossible.
