Manifolds. Mount RIGHT in the way!!!!!!!1
Old Aug 3, 2008 | 04:54 PM
Camarothatcould's Avatar
I have all the exhaust manifold bolts out, well least the ones that weren't already broken off, the last one, 2nd bank back bottom stud is RIGHT BEHIND the engine mount plate!!!! WTFH!!! I cant even get a socket inbetween there, and if I could, there is not even enough room to back it out all the to clear the mounting plate!!!
Do I honestly have to jack up the motor and remove the engine mounts to get this last bolt out????
Old Aug 3, 2008 | 05:18 PM
polpilot's Avatar
When i put my headres on i had to unbolt the passingers side motor mount to get them swaped.... your dealling with the pass. side right... i have heard of people not having to do it, but its not that hard.... good luck
Old Aug 3, 2008 | 05:35 PM
chiefFX4's Avatar
hell just get some vice grips. i think that was my tool of choice for removal of the manifolds.
Old Aug 3, 2008 | 09:09 PM
I got the nut off that particular bolt, but then the edge of the manifold would not clear the mount. I jacked up the engine and unbolted the mount. pics in a fews. . .
Old Aug 3, 2008 | 09:18 PM
the item to the left is the engine mount. You can see how close it is to the nut. but then notice, even if you do get the nut off, the lip of manifold wont clear it.
Two studs broken off prior to me gettin gin here, hence the ticking. the far upper left and exact opposite lower right, first bank. both broken clean off INSIDE the head
I have my work CUT out for me just nice. Next few days drilling and tapping into precious aluminum. great.
Cleaned up a little
I dont think I am putting studs and nuts back in, just going to use bolts and lock washers. case hardened junk.
Old Aug 3, 2008 | 09:25 PM
jbrew's Avatar
You can use a ratchet wrench , well, that's what I used installing headers. To remove the old studs on my 98 - I used an Impact w/ 2 universals. Just a cheap little battery Impact was all it took. They look like hell on the outside, but they all spun right out. -
BTW - Mine were 12mm & 13mm. Studs were 5mm.
Old Aug 3, 2008 | 09:28 PM
I was busting off three and the nuts took the studs with them out, thnak gob. The rest I had to get the vice grips out for, but I did not break off any.
What did you use for aftermarket replacements?
Old Aug 3, 2008 | 09:51 PM
jbrew's Avatar
I had to use shorter header bolts - They came with the headers.
The studs came out w/impact -A 5mm socket fits the studs, but yea , most came out the same way yours did - Nut, stud in one shot. I had both sides off in about 20 minutes. I was surprised, thought it would be a b^tch.
Old Aug 3, 2008 | 09:58 PM
jbrew's Avatar
The 98 -
Drivers side -
Passenger side -
Old Aug 3, 2008 | 10:00 PM
Wow. everything is so clean. . . .
how much were those and what brand?
Old Aug 3, 2008 | 10:05 PM
jbrew's Avatar
Yea, I've been very lucky with this motor - 241,000 miles and it's never leaked a drop of oil - Doesn't burn any either, between changes - But the oils changed every 3000 miles, so it doesn't have much of a chance to burn any - Always ran Castrol Syn Blend.
Those are Pacesetter LT headers.
Old Aug 3, 2008 | 10:12 PM
I would guess you polish the heads every week or so, jesus h.
how much were those headers though?
Old Aug 3, 2008 | 10:17 PM
jbrew's Avatar
No , I cleaned them up just for pictures sake - The one and only time - Hell , I couldn't even see the manifold nuts before I cleaned it up.
Pacesetters were $239 or 249 for the everything.
Old Aug 3, 2008 | 10:20 PM
Not bad. Wish I had that. Wouldnt be worth it though, tired ole 4six is about to turn over 170k and shouldnt be staying too much longer
Old Aug 3, 2008 | 10:25 PM
jbrew's Avatar
Hey your in Indiana ? I'm out here as well, for awhile anyway, until this job i finished. I'm right by the Indiana/Illinois line tho. Small world ehh..
