check engine light is on
Old Jun 28, 2008 | 04:06 AM
king ranch's Avatar
today i got gas from raceway and after getting gas 10 mins down the road it started running really bad and then the cel came on and i used the edge to find out and clear the light it said 6th cylinder missfiring and i was wondering why is that
i think its from ****ty gas bc i only had like a 1/8 of a tank when i put gas in my truck and i usually use bp fuel but reaceway was teh only place open
so how can i make sure nothing is wrong with my truck
when i got home i put 93 octane in it and put my edge on level 3 hoping it will solve the prob
my truck only has 78k miles on it also since i am here asking for some advie being the miles on it and never changed any fluids but oil of course no tranny or nothing what mainteance should i do to get more power from the engine and a lil better in takeoff
Old Jun 28, 2008 | 05:01 AM
roushstage2's Avatar
Is the CEL light still on? Was the code P0306? If so, check the plug and the COP.
Old Jun 28, 2008 | 05:18 AM
MmmBuckles's Avatar
first thing i would do it check the plug and and COP. then look for a vacuum leak
Old Jun 28, 2008 | 05:45 PM
king ranch's Avatar
i dont rember the code but it said 6th cylinder missfiring and i cleared it and since then the light hasnt came on but it still is running a lil rough but i havent got all the bad gas out i dont think yet
i think its just the gas
Old Jun 28, 2008 | 07:49 PM
JMC's Avatar
JMC
25 Year Member
If you suspect bad gad don't go to a higher tune. Why put more stress on the engine with crap gas and a hotter tune? Get some gas line antifreeze and put a few bottles in the tank.
Regards
Jean Marc Chartier
PS. when all is said and done and things are back to normal change the fuel filter.
jbrew's Avatar
Fuel filter ? With the gas that low before fill up you might have churned something up in the tank.
Idunno - that's kinduh far fetched...
First thing to do is get a fresh filter installed, you might get away cheap and less work.
Old Jun 28, 2008 | 08:01 PM
x_sgs_x's Avatar
Filter sounds like your best bet.
Old Jun 29, 2008 | 11:51 AM
78k and a P0306 - #6 plug and/or cop is quite suspect. So is #6 injector if you got some really crappy gas and you haven't changed the fuel filter in a while.
Old Jun 29, 2008 | 06:09 PM
king ranch's Avatar
never changed the fuel filter and i usually always get gas at bp and then i got it one time at raceway and it started acting up on me
where is the filter and how hard to change
