misfire
Old Jun 22, 2008 | 11:08 PM
Stephen87's Avatar
misfire
I have changed all the spark plugs(with motorcraft) the wires(with borg warner) and the coil packs (borg warner) and it still says misfire on cylinder one
any ideas as to what might be causing this and as far as I can tell all of the plugs are gapped correctly
Old Jun 23, 2008 | 06:41 AM
torkum's Avatar
Possible injector problem.
Old Jun 23, 2008 | 07:01 AM
tech-doc's Avatar
switch the #1 injector with the #2 injector, and, reset the computer. If you get a #2 misfire the next CEL, your injector is bad.
Let us know what the outcome is.
Good Luck!
Old Jun 23, 2008 | 01:33 PM
Stephen87's Avatar
I am gonna have to try that I did not think that it was the injector
Old Jun 23, 2008 | 02:44 PM
morris150's Avatar
Dont feel bad your not the only one doing this Sh*t !! I got a set of COP's on the way and motorsraft platinum plugs on the way be looking at the injectors next if this dont work may just go on and change them out anyways..
Good Luck..
Morris
Old Jun 23, 2008 | 11:39 PM
Stephen87's Avatar
I looked at the price of 8 new injectors and even with my employee discount at o'reilly auto parts it is freakin expensive...it is about $400 for all 8 of them so I hope that if it is bad that the others dont follow suit
and today I unplugged the injector in cylinder 1(it felt like the rpms dropped but not by much) then plugged it back in then unplugged the one right next to it cylinder 3(I think)and it felt like the rpms dropped a little more but I cannot confirm that because I do not have a tach installed on my truck not yet at least
Old Jun 24, 2008 | 03:00 AM
tech-doc's Avatar
You can find them on ebay for alot less than that. http://cgi.ebay.com/ebaymotors/8-For...spagenameZWDVW
Now, your PCM is telling you there is something wrong in the #1 hole. By *SWITCHING* the #1 and #2 injector and resetting the PCM, you will be able to know FOR SURE if the injector is indeed bad. Because, if so, your next code should read #2 misfire, if the injector is indeed bad.
Old Jun 24, 2008 | 12:26 PM
Stephen87's Avatar
assuming that it is bad and also knowing that I want to one day get a supercharger should I just get performance injectors or should I just wait until I get the supercharger and get a cheap one for now
Old Jun 24, 2008 | 03:26 PM
Stephen87's Avatar
Ok so I changed the injectors around and erased the codes and then drove around abit and the code did not stay away it came back
Old Jun 24, 2008 | 05:59 PM
tech-doc's Avatar
I hate to be able to predict the FUTURE, BUT, WHATS The dern code?
No, if you want to do a SC, LATER IN LIFE, you don't add bigger injectors NOW!
Or am I wrong, but, did the carts push the horses in the old days, or did the horses PULL the carts? Can't remember???
Old Jun 24, 2008 | 09:34 PM
Stephen87's Avatar
heh...sorry if yall did not catch it but I meant it as the same code came back P0301
there is also egr insufficient flow wihitch I cannot seem to get rid of (replaced egr and sensor)
Old Jun 24, 2008 | 10:32 PM
Quintin's Avatar
Cleaning the EGR ports will get your insufficient EGR flow code fixed.
And I'd be checking compression and leakdown on cylinder 1, assuming spark and injector pulse is okay.
Old Jun 24, 2008 | 10:35 PM
Stephen87's Avatar
yea that is the next step for me I am gonna get a compression tester and test the compression on the engine
