how to start your starter with screwdriver ?
Old Jun 20, 2008 | 09:10 PM
dallas63's Avatar
how do you start your starter with a screwdriver ?
Old Jun 20, 2008 | 09:15 PM
chiefFX4's Avatar
put the metal part across the two terminals and make sure you are only touching the handle of the screwdriver.
i dont think you really start the starter that way, just jump it to see if its getting power.
Old Jun 20, 2008 | 09:29 PM
dallas63's Avatar
how to start your starter with a screwdriver ?
i am broke down at home . the guy at the shop said i could turn the key on and touch something with screwdriver . he said it should start to drve to shop .
Old Jun 20, 2008 | 09:49 PM
shifty_85's Avatar
yeah ull have to take the lil red thing off the postive cable and the key will have to be in the on postion *EFI* ....if your starter is dead then doing this wont start your truck... im kinda of confuzed on why your wanting to do this...
Old Jun 20, 2008 | 10:09 PM
jbrew's Avatar
Because he doesn't want to fix it . - His problem really isn't that difficult to figure out - IMO.
Old Jun 20, 2008 | 10:52 PM
dallas63's Avatar
no its not that i dont want to fix it . i tried all afternoon and i only got 1 bolt out of starter . i found 2 bolts but not the 3rd one . i cant get the 2nd out with my ext and socket . i just want to start it . so , i can drive it to the shop . thanks
Old Jun 21, 2008 | 12:23 AM
Klitch's Avatar
lol. man you need LT headers so you can appreciate the room between the stock manifolds and the starter... seriously the top bolt is damn near dead above the bottom. probably kicked outside 1/4" or so?
what do u mean by u only got one bolt out?
Old Jun 21, 2008 | 03:13 AM
jbrew's Avatar
Yea it's a b^tch with headers now - I can still get it tho. I can have the starter on the bench in about 8 minutes - I've had the damn thing out about 5 times in the last year
I go thru the inner fenderwell - much faster than from down below.
Old Jun 21, 2008 | 03:28 AM
Bartak1's Avatar
7 minutes and 58 seconds for me....whatcha think bout that ehh???
Thats right....I win
Old Jun 21, 2008 | 04:28 AM
Fifty150's Avatar
congrats, would you like a batman cookie?
Quote The Raptor
Old Jun 21, 2008 | 05:34 AM
jbrew's Avatar
Originally Posted by Fifty150
Quote The Raptor
"Quote:
congrats, would you like a batman cookie? "
Nah, would you like a hurts donut ?
Old Jun 21, 2008 | 05:40 AM
jbrew's Avatar
Originally Posted by Bartók
7 minutes and 58 seconds for me....whatcha think bout that eh???
Well I really did in 6 minutes flat - 8 just sounded more believable. - So , hope there's a conciliation prize for yuh.
Old Jun 21, 2008 | 05:42 AM
PKRWUD's Avatar
I don't know what year your truck is, but there should be a starter relay on the fender near the battery. Just follow the positive battery cable from the battery, and it should go straight to it. You will see another battery cable attached to a second post on the relay, this cable goes to the starter.
Turn your ignition ON, and using two large screwdrivers, place one so that it rests on one of the large relay posts, and the other screwdriver so it rests on the second large post, and then cross the screwdrivers so the shaft of each touches each other. There will be a large show of sparks, which will startle you, but don't worry about it. The starter will spin, and if all else is good, the engine will start. Remove the screwdrivers as soon as it starts.
Old Jun 21, 2008 | 12:12 PM
RacingJake's Avatar
Why remove the starter just to bolt it back up if it's bad.
I'd check the fuses and/or replace the soleniod first. Cause if the fuse is bad most likely it's the soleniod on the firewall.
Old Jun 21, 2008 | 05:39 PM
jbrew's Avatar
Yea that relay (or solenoid on the firewall) in his model relies on one of those little black fuses - Says that on the service DVD - I looked it up yesterday for him(he has two threads going on this issue ), but he didn't reply
I think it was fuse #32.
Here's his other thread - https://www.f150online.com/forums/sh...d.php?t=337034
He has more than enough info to find the problem IMO - Just not doing as advised.
