What is this?
Old Jun 6, 2008 | 06:42 PM
Pinhead-227's Avatar
What is this?
It's between the battery and the firewall.
The one on the left has a white vacuum line going to it; the line is broke. What will this effect and how can I fix it? It's a hard plastic line so I can't simply splice it like you could with a rubber vacuum line....
Old Jun 6, 2008 | 06:59 PM
kingfish51's Avatar
Well if you want to go in and out of 4x4, you will get the line fixed. Those are the solenoids that control the engaging and disengaging of the front diff when you put the vehicle either in or take it out of 4x4. One is for locking the front diff and the other unlocking. Can't remember which is which though. The lines are vacuum lines to the front diff.
Old Jun 6, 2008 | 07:06 PM
Ah, I see. I guess that explains why I haven't had any drivability problems or codes. Thanks!
Is there a magic method for fixing the hard plastic vacuum lines??
Old Jun 6, 2008 | 09:19 PM
f150boudreaux's Avatar
have you tried a parts place. i know some heavyduty truck parts places have splices for differt size air lines.
Old Jun 7, 2008 | 12:05 PM
kingfish51's Avatar
When I had my 98, I had the problem, fortunately under warranty. They were able to fix it without replacing with a splice.
Old Jun 7, 2008 | 12:08 PM
4x4 parts, that why ive never seen those before
Old Jun 7, 2008 | 12:56 PM
jbrew's Avatar
Yea the Blue and Pink lines severed on my 98 once - Actually I think they just got old and brittle.
Old Jun 7, 2008 | 03:50 PM
JMC's Avatar
JMC
25 Year Member
The white line is the vacuum source for the front axle engage solenoid. If that one cracked the others are not far behind. The white one comes from behind the battery. Pull the battery and the box ant follow it to a Y connector. It should be on the same line as the black line that feeds the disengage solenoid. Luckily there is a check valve on the vacuum reservoir feed line from the engine that keeps leaks like this from causing driveability problems.
I replaced mine with rubber vacuum line. Buy some small zip ties, red, blue, white and black. Attach them to both ends of the lines when all is installed. That will help you keep track of which line is which. if you buy black hose you don't need black zip ties.
Regards
Jean Marc Chartier
Old Jun 7, 2008 | 03:54 PM
Queso's Avatar
First post but been lurking for a long time. I joined because I saw your problem but wasn't satisfied with the solutions posted so far.
It's a really easy thing to repair. If it's not already completely broken, break it in two or cut it with wire cutters. Then get a 3" or so piece of regular rubber vacuum hose and just slip the ends of that plastic line into the vacuum hose- voila, problem solved! The plastic stuff fits into the rubber vacuum line very nicely.
Old Jun 7, 2008 | 04:31 PM
jbrew's Avatar
It's about time you joined - For an air tight repair, dip the rubber sleeve into mineral spirits / this shrinks the rubber around the existing line -
Info via "Ford Service". They even have a diagram of it
Old Jun 7, 2008 | 05:43 PM
Queso's Avatar
Thank you, sir. I hope I can make a positive contribution to the site. There's no way I could ever repay for all that I have learned from the user community here.
Old Jun 7, 2008 | 06:00 PM
jbrew's Avatar
No problem. It's all about users experiences, there's allot of them here. Sh^t happens that needs fixing. Searching the past thru the search bar (forum specific search bar) has endless info and data to draw from. Consumer/field experiences are the best kind when troubleshooting for the average joe. This is one of the best sites on the web for that and it's free.
