maf cleaning
Old Jun 8, 2008 | 12:21 AM
FF301's Avatar
maf cleaning
1 st? were is the maf located on a 97 4.6L does anyone have a picture?
2nd ? -should i run sea foam through one area at a time or can i do all (oil, vacuum line and fuel) at the same time
Old Jun 8, 2008 | 02:21 AM
Vince97's Avatar
MAF Cleaning
Hi
If its anything like the 5.4L, open hood. Remove clamp from air filter and split the housing. As you are looking at it, filter on the right, maf on the left. There are 4 tabs you depress with a slot screw driver, then that round part that mates with the air filter will come out, disconnect the electrical connection, need a small hand to get back in there, then the round piece comes out. This is the link to the website, look in the right hand column, you will see the MAF article. http://www.fordf150.net/howto/. I did this with good results. Little more power, but I did loose a little in the MPG category, not running as lean as before.
Old Jun 8, 2008 | 02:22 AM
jbrew's Avatar
1rst - http://www.fordf150.net/howto/clean-...low-sensor.php
2nd - Seafoem is snake oil / I wouldn't use it. Others have tho and like it
