5.4 spark plug removal problem
Old Jun 3, 2008 | 09:07 PM
wreedKR's Avatar
How can I tell if my truck is goin gto be subject to the spark plug removal problem, I heard Ford fixed it in later model 5.4s, any way to tell?
Also can anything be done to prevent the problem now?
Old Jun 3, 2008 | 09:14 PM
azmidget91's Avatar
ford never really fixed it, but alot of people suggest pulling the plugs as soon as possible and use some anti-sieze
Old Jun 3, 2008 | 09:56 PM
minimonster17's Avatar
there is some controversy on the use of anti-seize, however, if you do opt to use it, do not torque the plugs as tightly as you would w/o it. also, having the rotunda tool just in case is a good idea. if the plugs are broken, stuck, and deemed non-removable the heads will have to come off, not a cheap route.
Old Jun 3, 2008 | 10:21 PM
Antiseize MUST be used on the ground shell, and NOT on the threads.
It's fixed now, but I dunno how many improved engines are out there yet. Your 07 won't have the redesigned heads.
Old Jun 3, 2008 | 10:26 PM
jethat's Avatar
I've never heard about a controversy about antiseze on the bottom of the plug in the 04+ engines. Some people don't like it on the threads but I would defiantly coat that extension bottom of the plug deal.. I think at 30 k I would pull them..
