Exhaust manifold gaskets
Old Jun 5, 2008 | 04:20 PM
keith97xlt's Avatar
there was a guy over on the crown vic site that took a small dremel tool spiral cutting bit and grinded a slot on top of the busted stud and he spun it out with a flathead screwdriver. of course this only works when its busted flsush with the manifol or a little above it.
Old Jun 7, 2008 | 01:25 PM
rescuenut10's Avatar
I also think that I have the dreaded leak. What should something like that cost to repair?
Old Jun 7, 2008 | 01:54 PM
98f150guy's Avatar
Hey guys. I just completed this project on my 98 f150 4.6. Driver side manifold. The toughest part of getting the manifold off was getting the socket to the rusted bolts. Another universal socket would of been nice. But I made due with just one. I also had one broken stud on the rear. Gaskets were $12 from auto parts store. 2 piece design. Best advice I can give is spray the crap out of it with PB Blaster the night before and again a few hours before you attack it. Then for the busted stud I used a pair of vice grips.
Old Jun 7, 2008 | 05:31 PM
Camarothatcould's Avatar
I have SeaFoamed it, I did not get a single bit of smoke. I made a thread about it few weeks back. Since I dont really drive my truck that often, I think I will tackle this soon. I will ofcourse keep you guys updated. . .
Old Jun 8, 2008 | 03:32 PM
Bent6's Avatar
25 Year Member
I'm not sure if they still have them, but Ford used to offer copper plated stainless studs which were supposed to be much better than the factory studs. It's probably a worthwhile upgrade at least on the outermost studs.
Old Aug 14, 2008 | 10:53 AM
lovemyexpy's Avatar
jbrew, I'm impressed that you could remove the manifold studs with the Ryobi Impact. I assume it was this one?
http://www.homedepot.com/webapp/wcs/...3+90401+527286
It looks like you just let the rusted nuts stay on the studs and backed out the whole stud/nut assembly with the impact?
Thanks.........
Old Mar 16, 2009 | 07:21 PM
Birdman98's Avatar
Minimonster do you still have the 5.4 manifolds and do they fit a 0998 F250?
