Recharge A/C Question on fluid
Old May 28, 2008 | 07:15 PM
BobK's Avatar
Keep in mind if you go to a shop it is illegal for the shop to recharge a system that has an identifiable leak.
That's a common belief but not true:
http://www.epa.gov/Ozone/title6/609/wantknow.html#q10
Everything I've read about those cheap vacuum pumps has said to stay away from them, the only thing they are good for is wearing out an air compressor. A good A/C vacuum pump is generally pretty expensive ($200+) but you can sometimes find them cheaper in a pawn shop.
If it's only empty because you accidentally opened it up and you just need to get it vacuumed and refilled then take it to a Jiffy-Lube type of place and get it done.
The tools to work on an A/C system aren't cheap but they will pay for themselves after a couple of repairs.
Also Sam's Club has great prices on R134a, I think a case of cans was $36 last time I looked.
Old May 29, 2008 | 03:41 PM
rmeidlinger's Avatar
been using one of those cheap devices for over 20 years- never had a problem and never wore out a compressor.
