plug recommendation
Old May 19, 2008 | 01:43 PM
jack_craig's Avatar
plug recommendation
hi folks,
i have 215k on my 5.4L 4x4 automatic daily driver. in a recent dealer screwup,
they neglected to replace my sparkplugs. i wanted it done as they are due.
however, now that i missed the opportunity to get oem plugs installed by default, i am wondering if there are other spark plug options that would fit my application and add a bit more zippiness to my daily ride?
anyone?
tia, jackc...
Old May 19, 2008 | 03:32 PM
RacingJake's Avatar
You can't beat OEM
Old May 19, 2008 | 06:13 PM
jack_craig's Avatar
hard to believe
this is the very assertion i was looking to verify. ford claims their 100k mile plugs are best, what do the independent users have to say?
with all the aftermarket options, its hard to belive there isnt a more robust, maybe more explosively burning plug?
i gotta replace them so now is the time for me to ask...
Old May 19, 2008 | 08:11 PM
Matts ford's Avatar
ford plugs are made by autolite just to ford specs. autolite makes the best but they arent built to ford specs under the autolite part number and sometimes the 5.4 and 4.6's don't run right with them but they run excellent with the ford plugs so i'd go with the ford plugs.
Old May 19, 2008 | 09:28 PM
Ford_Polaris's Avatar
Stick with Motorcraft or Autolite. If you use any other brand, you will have problems.
Old May 19, 2008 | 10:20 PM
chiefFX4's Avatar
stick with motorcraft. i wouldnt run the risk with autolite.
theyre made by the same people, i know, but the motorcrafts are specd different arent they?
Old May 19, 2008 | 11:07 PM
DVD_FX4's Avatar
Get the brisk silver racing plugs or the new motorcraft replacement plugs. Stay away from the champions.
Old May 19, 2008 | 11:48 PM
shifty_85's Avatar
Cant beat motorcraft in fords
i tryed autolites in my truck and the misfired after only 5,000 miles my motorcrafts have been in my truck for 10,000+ miles on them
Old May 20, 2008 | 06:48 PM
jack_craig's Avatar
thx for your time gents, i appreciate your guidance, jackc...
Old Jun 2, 2008 | 09:55 PM
supercrewser13's Avatar
I HAVE 2003 5.4 whats the part number or the motorcraft
Old Jun 2, 2008 | 10:29 PM
If you go to Rockauto.com and look up the plugs for your year and engine, it will list a bunch of plugs, Motorcraft included.
Old Jun 3, 2008 | 12:54 AM
jbrew's Avatar
http://www.autopartswarehouse.com/se...20Ford%20F-150
Old Jun 3, 2008 | 08:59 AM
looks like i have the wrong set from ford.
Old Jun 3, 2008 | 10:50 AM
jbrew's Avatar
What Motorcraft (Ford) part # are they ? 22's , 479's ? They changed the numbers + the 03 has different plug chambers. The best plugs for your model is the fine wires IMO. Cross Reference the plug #'s in the link I provided w/glc's suggestion " Rock Auto" - Compare numbers.
Old Jun 3, 2008 | 10:54 AM
Yeah i definently had the wrong ones i called the dealer today and they swaped out the set i had for sp 479 i beleive they gave me the sp 482 which is for older mustangs and thunderbirds and some 5.0 engines it looked to be.
