plug recommendation
Old Jun 3, 2008 | 01:18 PM
tech-doc's Avatar
Originally Posted by glc
If you go to Rockauto.com and look up the plugs for your year and engine, it will list a bunch of plugs, Motorcraft included.
WOW! You are stepping on the toes of your own hipocracy now, glc!
What is wrong with giving members part numbers? I guess, this means, that you are above your own comments huh? Tippie toe around me friend!
Old Jun 3, 2008 | 04:13 PM
At least I said exactly where to look them up, arsehole. I also posted the exact numbers in his real thread.
Old Jun 3, 2008 | 06:30 PM
ssj4shane's Avatar
tell you the truth any iridium plug that will fit in the motor with the same heat range should dooooo just fine....
I run the denso iridium's
Old Jun 3, 2008 | 07:42 PM
Denso's are fine as long as you use the correct heat range. That's what Troyer sells as part of their ignition upgrade kit.
Old Jun 13, 2008 | 11:06 AM
97 ford f150's Avatar
i have a 1997 f150 and they put champion plugs in the truck and it runs like crap. i put autolite plugs in and runs 100% better run autolites or motorcraft
Old Jun 13, 2008 | 02:00 PM
jbrew's Avatar
Your one of the lucky ones then- My truck ran for 40 miles on Autolites. Then it started running on 6 cylinders. Had to to Install Motorcrafs to fix. Autolites don't work well / wrong heat range and NOT Ford spec.
The 97,98 5.4L COP'ed motors are picky as hell when it comes to plugs.
