best time to change plugs?
Old May 15, 2008 | 10:29 AM
illness95's Avatar
should u change plugs when the engine is hot or cold ??i forget.. i havent done it in awhile
Old May 15, 2008 | 10:42 AM
Cold.
Old May 15, 2008 | 10:44 AM
Buzsaw's Avatar
Do it cold. Use an air compressor or bicycle pump to blow debris away from the plug hole before removing plug. Use a torque wrench when tightening.
Old May 15, 2008 | 11:55 AM
illness95's Avatar
thank you
Old May 15, 2008 | 09:29 PM
lowflyingbird's Avatar
Before it blows out of the head
Sorry Ive had a couple.
I couldn't resist.
But all kidding aside, YES when it's cold. I let any vehicle sit over night or at least a few hours before doing plugs on an aluminum head. I recomend antiseize on the new threads as well. Forgetting about all the people stating various reasons why they do or dont, think about it... a steel plug thread in an aluminum head, then add heat. Threads bond some times, other times corrode. Antiseize solves both, and remember only a fool believes that plugs should be changed at 100kmi. The plug might last 100kmi. but it might shoot out, or bond to the head also.
Lowflyingbird
Old May 16, 2008 | 03:14 AM
jbrew's Avatar
Plugs blow out of the heads ? Huh, never heard of such a thing.
NO anti -seize - Trust me , you want those plugs to bond, although I never seen that happen in your model. Engine @ room temp before change or you WILL mess up those threads a little.
What I have seen personally, is couple plugs loosen up inside of 10,000 miles w/anti-seize. Cleaning the threads and purchasing a NEW can of Nickle anti-seize didn't help either. Tried Copper and Nickle -No change. except 3 & 4 lost torque.
A well known Tech on this site suggested not using it. He said that he doesn't use it on 4 thread heads.
That worked for me, they stay tight.
BTW- I have thought about it, ALLOT! - Finally, with time, I was able to find out myself what was best.
Old May 16, 2008 | 07:30 PM
illness95's Avatar
i thought the heads on my 4.6 were iron?? hmmm u sure they are aluminum??? and the only plug spitting issues i have ever heard of were on the 5.4s... Ive never heard of a plug spitting out of a 4.6 head... Ill prolly end up using antiseze as i have never had a problem with it.. nor have a i ever had a problem not using it.. oh well..
