Lousy Fuel Filter Line Design
Old Apr 24, 2008 | 04:55 PM
jbrew's Avatar
Originally Posted by McLovin
It may seem like it requires 3 hands to do this, but push the line and the filter together while trying to slide the tool into the line. Betchya' that gets it
That's what i do - Forward , then yank that puppy back.
BTW- Good luck getting that third hand in there - Use that one to hold your Cig
Old Apr 24, 2008 | 05:37 PM
energizedsbs's Avatar
just changed mine last saturday. the inlet from the tank took 10 seconds. the oulet took 30 min. I had the tool put it was a pain. You have to push on the fuel line one way and the oppisite way with the tool as hard as you can. I felt a little click and it slide right off after yelling at it for 20 min.
Old Apr 26, 2008 | 02:17 PM
ceb66's Avatar
Like "Req" advised, I used the plastic tool w/ WD-40 and it finally released. The metal tool wouldn't work. The clip's going to have be replaced soon. It was a nightmare trying to get it to release.
Simple job that turned into a pain.
CB
Old Apr 26, 2008 | 02:32 PM
jbrew's Avatar
Yea , the outlet is the bad one. The plastic tool will get damaged after awhile which makes it even more fun unless you have plenty of those on hand.
This is the best tool for the job IMO -
There's 3 pieces and they rust on there pretty good at times. This filter came off a friends truck. As you can tell - It pi$$ ed me off a little.
The clips your trying to release look like this -
Old Apr 28, 2008 | 01:41 AM
po1911's Avatar
heres what i did today taking the fuel tank out today so i could get to my fuel pump the little plastic disk type release tool broke and the closest parts store to me is 26mi so i improvised. its the cut off end of a crazy glue tube with a 1/4" or so section removed from the side it worked like a charm in fact ill most likly keep it in my drawer and not worry about replaceing the little disk thing
sorry tried to add pic but i still havnt figured that part out yet
heres the link
http://s287.photobucket.com/albums/ll160/po1911/
