06 5.4 3v plug change
Old Apr 21, 2008 | 04:30 PM
sam1947's Avatar
Just a quick reference link: http://www.drillspot.com/products/28...eize_Lubricant
Old Apr 22, 2008 | 12:31 PM
I don't think I've ever seen any antiseize that's blue - the required nickel stuff is silver. I would believe that Loctite makes antiseize, but when someone says "Loctite" we all assume that means a liquid thread locker. That stuff is definitely a no-no on *any* spark plugs.
Old Apr 22, 2008 | 02:58 PM
sam1947's Avatar
I agree with you 100%. The stuff I have been referring to is silver, as it should be. If the stuff the OP used was indeed was the blue 'Locktite' stuff, then may God be with him when it comes time to change the plugs again.
Old Apr 22, 2008 | 03:10 PM
Blue loctite is service removeable. I'd think most of it would burn off with the high temps anyhow. I'd never put it on my plugs though. That is retarded.
Old Apr 22, 2008 | 04:18 PM
I also wonder if the OP realizes the antiseize needs to go on the ground shield barrel, NOT the threads?
Old Apr 22, 2008 | 04:19 PM
I still wonder if he is legit.
Old May 1, 2008 | 02:47 PM
frankiemcnoosie's Avatar
UR an A$$!
Do you wonder if any person posting is legit?
I got the troll you all wish for right here in my pants!!!
MORONS!!
Old May 1, 2008 | 02:55 PM
Originally Posted by frankiemcnoosie
UR an A$$!
MORONS!!
You just seem to not see the humor of someone using "locktight" on plugs that we all are praying will come out. Since people pop in from time to time trying to stir things up, it was normal I think to wonder.
Old May 1, 2008 | 03:23 PM
For someone who claims to be legit, these are some pretty strange posts:
I use RP in my 10 speed and no snakes have chased me since!!
Good Chit!
Question:
I want to hook up my efan's low speed to the ac clutch switch, which of the 3 wires going to the ac compressor do I tap into?
Thanks for any responses.
Answer:
That one right there.
Connect it to the canadian ground and you will be scotch free!
(you said thanks for any correspondence) LMFAO!
Better break out some more troll spray.
Old May 1, 2008 | 03:35 PM
EXACTLY! YOU CALLED ME A TROLL!! I WILL GIVE YOU ONE!!!
Since you are the "MR. MArshall" of the forum!!
MORON!!
Old May 1, 2008 | 03:38 PM
I am sure you took offense to the canadian ground. Am I right?
Come on, admit your an idiot! We all know it is true.
Old May 1, 2008 | 06:45 PM
Old May 1, 2008 | 06:53 PM
last5oh_302's Avatar
X2
