98 F150 V-8 5.4 won't start
Originally Posted by advisual
I have a long heavy guage wire I can run from the positive battery terminal directly to the starter. Where do I touch it to the starter and do I need to ground it at the same time?
If the problem is the ground , then you'll need a gound lol .. I would just remove all the cables , clean the connectors / grounds / test...
You didn't say or I missed it - Did your old starter have the same problem ?
it still could be, me and JMC questioned the braided positive wire that Jbrew posted a pic of. i never saw you actually rule it out. remove it and clean that terminal next time ur under there checking things.
oh HA i didnt see the posts on 2nd page. this is a fresh starter?
start cleaning all your grounds (related to starter) and positive contacts.
hey uh, your battery IS good right? have a friend watch the voltage on it when you try to start it. see if it drops real low.
Does anyone have a picture or diagram of what wire connect to what at the starter to make sure I connected them properly. Right now the braided wire is connected and tightened down but nothing connects to that bolt currently. Should one of the wires be connected there?
on
There seems to be a wee bit of confusion. There are two red wires going to the Starter. A fat one that comes from the battery and is most likely corroded. A skinny one that comes from the relay on the firewall, yes sir it is called a relay. The skinny one activates a solenoid on the starter and the motor draws current from the fat wire. Jump the fat red wire directly to the positive battery terminal. Now try starting the engine. If successful replace the fat red wire. If not run a ground from the negative battery terminal to a ground point on the starter and try again.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
Well guys unbelievably the fix was so simple I overlooked it. Turns out it was corrosion in the wires that attached to the positive terminal. When I cut off about 1 inch of the wire and used a wire brush and a little coke to clean the clamp it started right up.
Thanks to all of you for all of your help. I hope to return the favor in the future.
on
Guess what. I noticed that my connector for the fat wire was corroded when i got under there to figure out what to post but I chose to ignore it. I noticed it again when i checked the header bolts to insure no leak. So I went to the grocery to pick up a few things............ The suspense is killing me. I went to start after load the groceries and I got the CLICK! 3 times I tried till my brain kicked in and associated the afternoon viewings with the problem. I was on a bit of an incline so I tried letting it roll but she would not pick up enough speed. Well I always carry tools. POP the hood, disconnect the NEG terminal and under the truck I go. With my 13mm in hand I proceed to loosen the nut holding the corroded terminal. Yup, its the fat one. As soon as I pulled the terminal off the post the wire came apart and I was left holding the corroded connector. What suprised me the most is that I didn't use any French Holy words. I rooted through my parts bag but nothing that would remotely replace the connector. Then light went out, or was that on? I split the wire down the middle and wrapped it around the terminal, tightened the bolt and made sure that there were no loose strands touching metal. Reconnect the battery and it fired right up. Tomorrow I will make a permanent repair. Sooooo....... Check the fat wire.
Regards
Jean Marc Chartier
Regards
Jean Marc Chartier
Glad you got it figured out .
These are Bussman Mega fuse holders. Hard to find.
Here's a pick of the same truck with the new Busmans installed, -
I guess Summit has them now.
http://www.summitracing.com/parts/bs...FbFaMgod8wIAzg
I had to mod the holder in order to mount them, - wasn't too bad.
