changing fuel filter
Old Apr 8, 2008 | 06:34 PM
Mo Power's Avatar
My 02 F150 uses a 5/16ths fuel line disconnect tool to get that filter off.
You don't need to bleed the pressure off. My rig was pressurized and only a few drops came down. After disconnecting the fuel filter, plug the ends of the filter to prevent more fuel from spilling out.
Just be patient, it can be time consuming the first time
Old Apr 8, 2008 | 06:40 PM
markshickjr's Avatar
No just kill the engine and dissconect the lines you be fine
Old Apr 8, 2008 | 06:46 PM
BSL's Avatar
BSL
You'll shoot your eye out
Old Apr 9, 2008 | 01:55 AM
2002xlt4x4's Avatar
Hahahahahahah i deffinently laughed for bout 10mins after reading that BSL!
Old Apr 9, 2008 | 10:30 AM
The time I spent in the military working on aircraft instilled attention to detail and safety procedures. Depressurizing the fuel system prior to disconnecting anything is a safety procedure. The book would not recommend it if it didn't matter. Do what you want on your own truck, but it's irresponsible to tell other people that it doesn't matter and that they are chickensh1t if they bother to do it. There is a hazard POTENTIAL here.
Old Apr 9, 2008 | 10:56 AM
R1Jester's Avatar
Takes 3 seconds to press down on the valve, with a rag covering it. Better to be safe.....
Old Apr 9, 2008 | 03:54 PM
tnsilverfx4's Avatar
what do you do if you don't have a valve and you cant let it sit overnight?
Old Apr 9, 2008 | 03:57 PM
You just change it. I'm telling you, there will be no pressure. Just the normal runout from the line and the filter. have a rag handy, grab the ends and tilt them.
Old Apr 9, 2008 | 04:21 PM
Lol, all right im doing this when I get back from work. If fuel sprays in my face its all your fault
Old Apr 9, 2008 | 04:30 PM
I think it may be time for a little vacation!
Old Apr 9, 2008 | 04:42 PM
buzzsaw714's Avatar
when I changed mine the fuel just poured out a little not sprayed out and it was not a big deal at all, however that was me... if I had the time I would have unpressurized the lines
Old Apr 9, 2008 | 11:51 PM
BSL's Avatar
BSL
figured someone would appreciate that
Old Apr 10, 2008 | 01:43 AM
jbrew's Avatar
I've done mine 23 times lol - Nah , I don't relieve pressure at the rail anymore since it never made a bit of difference. It does say to do so in the manual, so do as you will. I believe the pressure hold time is measured in the first 5 minutes after shut down. It bleeds off pretty quick after that. I'll have to test that on the gauge next time I test the pump.
My daughter did hers not to long ago. She didn't relieve the pressure because I didn't tell her to. - Guess that makes me irresponsible, BUT, didn't realize this may be an attempt to raise her not to be such a chicken sh^t
Old Apr 10, 2008 | 10:46 AM
This took me 15 minutes to do. I was more paranoid than anything else. I drove the truck home from work. I did some other chores I had to do around the house. I let it sit for about and hour- hour and a half. When i pulled the forward fuel line a little bit of gas came out. Nothing big by any means. I used the tool on the forward line and almost didnt need it. The rear line had a little bit more gas come out. The tool is needed there to pop the orange clip. Honestly this was one of the easiest things to do in the world. I cant believe how paranoid about this I was.
Old Apr 10, 2008 | 10:48 AM
I TOLD YOU! Can you believe the dealer charges $69 for that service?
