VIN question
VIN question
Wasn't sure where to ask this so if this is the wrong place i am sorry.I just purchased a 2001 f150 xlt extended cab from a guy i work with.He took the stickers off of the bed when he bought it,and i am also wondering if it came with a towing package.He also thought it had off road 4X4 stickers on it and i am going to replace them.Is there a way from the VIN that i can tell If this was an off road 4X4?Also if it came with a towing package? And does anyone here know what exactly the difference is between a 4X4 and a off road 4X4?The VIN is 2FTRX18LO1CA53282.
https://www.f150online.com/resources/vin.cfm
Thats a decoder offered here. As for further investigation, call a dealer and ask the parts dept.
So... not to sound sarcastic or anything... But shouldn't you be able to tell by looking at it if these options are on there? For example, if it's the Off Road 4x4 package, shouldn't you be able to look inside and see if there is a switch for the 4WD? And for the towing package, shouldn't you just be able to look to see if the trailer hitch is bolted into the frame vs. the bumper? I mean, I know there are different classes of towing, but... I dunno. I thought it would be as simple as the to tell. Am I wrong? Perhaps I'm just ignorant? Don't hate me...
Honestly dude, I've never owned a Fx4 or simple 4x4 F150. Mine was a 97
2wd so I wouldn't know. My nav has a switch on the dash by the radio for the AWD and 4x4 system. I had an explorer that had the same 4x4 switch minus the awd option that was a 95 year model. Beyond that, someone else will have to educate.
the 4x4 is just that a 4x4. the off road edition came with skid plates and off road shocks poss rancho. look under the truck and check for skid plates. also probably not a good idea to post your vin number for the whole world to see!
He's in atlanta, i'm in atlanta. whats to say I don't find his truck in a parking lot and write it down? What am I gonna do with it? Ford won't let you get a key cut without ABSOLUTE proof of ownership, and they have to have a trail of paperwork a mile long......plus the fact that ford only keeps key codes for 5 years and he has a 2001 so they can't even cut his key. The VIN is otherwise worthless and easily taken off any car in any parking lot at anytime. Convienently located right there in the corner of the winshield for anyone to see.
so i guess in atlanta they not have people who still cars and trucks and i guess in atlanta they don't have chops shops and i guess in atlanta they dont have identity theft. and with your vin you can access all the info about the registered owner and address and all that other good stuff from a crook with the right computer. i could keep going and going. i was only trying to help the guys out!
Hope this helps....
https://www.fleet.ford.com/maintenan...ls/default.asp
Edit..I entered your vin and 2FTRX18LO1CA53282 and the letter O has to be a zero for it to work
Originally Posted by VegasScrew
Hope this helps....
Try your VIN here - I believe you get a few options - It might help.
http://www.motorcraft.com/catalog.do?goto=vin
Or try OASIS -
http://www.motorcraftservice.com/vdirs/new_ocodes/
OR -
http://www.motorcraftservice.com/vdi...lt_nonus.asp?#
You might get something/ at least how she was shipped to the dealer.
Good Luck
Enter a 17 character VIN Number and click Find.
VIN Entry:
Year Make Model
2001 FORD TRUCK F150 PICKUP
Vehicle Type: Truck
Year: 2001
Make: FORD
Series/Model: F150
Chassis/Body Style: 4 Door Extended Cab Pickup
Engine Vin Code: L
Cylinders: 8
Displacement (CID): 330
Fuel: Gas
Wheels x Drive Wheels: 4 x 4
Shipping Weight (lbs.): 4,611
Weight Variance (lbs.): 400
GVW (lbs.): 6,001 - 10,000
Ton Rating: 1/2 Ton
Wheel Base (in.): 138.8-157.4
Original List Price (USD): 23,380
Price Variance: 6300
Air Conditioning: Optional
Power Steering: Standard
Power Brakes: Standard
Power Windows: Not Available
Tilt Wheel: Optional
Security System: Pass Key
Anti-Lock Brakes: 4 Wheel Standard
Daytime Running Lights: Optional
Standard Transmission: 5 Speed Manual With Overdrive
Trans Opt 1: 4 Speed Automatic With Overdrive
Standard Radio: AM/FM Cassette
Radio Opt 1: AM/FM CD
Standard Roof: Standard Roof
Or try OASIS -
OR -
Good Luck
VIN Entry:
Year Make Model
Vehicle Type: Truck
Year: 2001
Make: FORD
Series/Model: F150
Engine Vin Code: L
Cylinders: 8
Fuel: Gas
Ton Rating: 1/2 Ton
