Will opening up Intake on PI heads lose TQ?
Originally Posted by GodStang
Ok on the 4.6L PI head swap with Comp Cams will opening up the intake ports lose low end torque? Like Fox Lake stage II with they lose low end. I only care about low end TQ on this Truck.
Why would that happen?
Think about it...would choking off the intake increase torque?
Nope.
What would "lose torque" is a cam that provides only mid or higher range increases. If the cam in question doesn't kick in around 1500 RPMs, find another one. Power comes from enough air and fuel mixing and combusting and spinning that crank around. More air won't hurt if the engine can do something with it.
Originally Posted by built54
all the big ported aftermarket heads only add power.
When you say only add power I am guessing you mean high rpm HP. Do you lose any low end at all? Even though I mainly care about low end grunt if I do not lose low end then TQ then I may go ahead since everything is apart.
