stripped spark plug hole
Old Mar 19, 2008 | 07:33 AM
sawman's Avatar
hello everyone i have a 97 with a 4.6 and a year after i changed the plugs the #4 cylinder decided to spit the plug out and it took the threads with it. I put the threadsaver thing in it but it is missing pretty bad at lower rpm's. Any help/ideas would be greatly appreciated
Old Mar 19, 2008 | 07:52 AM
KEITHHATTER's Avatar
Is this what you used to fix the threads? http://www.timesert.com/html/triton_repair.html
It sounds like you are in need of a tune up (plugs and wires) and possibly new coil packs wouldn't hurt it any. My four six goes through plugs and wires every 60K miles and as always, use MOTORCRAFT plugs and wires. You can get a set of coil packs for under 100 bucks. This is what I used. http://www.autozone.com/selectedZip,.../selectZip.htm
When changing the plugs, take it slow, and, do it when the motor is cold.
You will find a wealth of info on this subjuct using the search tool above. Good luck and keep us posted.
Old Mar 19, 2008 | 08:16 AM
sawman's Avatar
thanks for the tips. yeah thats the same as what i used to fix it. i replaced one coil pack when i changed the plugs and replaced the other one after this happened. its still reading cylinder 4 & 7 missfire. i dont think the insert sealed very good.
Old Mar 19, 2008 | 09:02 AM
lowflyingbird's Avatar
Time for an engine upgrade, OR....
Another truck?.... BUT as far as an upgrade, you can do a PI swap now and justify it. Or keep in mind that you could have either a Romeo or windsor motor, and could drop in another one of either type much newer from a car cheaply. For some reason there is alot of BS reguarding using a car 4.6 motor in a truck. The only differences are the intake and oil pan/pickup. Cams and everything else are the SAME. Just upgrade the balancer if it's one with no meat on the front.
NOTE mid-03 and up have eight threads in the aluminum for the plug while earlier motors only have 3-4 threads.
Lowflyingbird
Old Mar 19, 2008 | 11:06 AM
sawman's Avatar
well, my dad bought the truck new and i got it when he passed away so i cant bring myself to get rid of it. the repair manual i got says it has the romeo motor. would the heads off a mustang fit and/or offer a performance gain. other than the sparkplug threads the motor is in good shape,and has always been well maintained.
Old Mar 19, 2008 | 11:41 AM
Did you by chance happen to change the plug wires when you did the plug change last time? Being as it is #7 as well, you can't really blame anything on the timesert not sealing.
This is not a "GET ANOTHER MOTOR" problem. The heads would be an option, but, simply and cost effectively, tracking down the culprit will be the best way to go.
Once the facts are narrowed down, you are bound to find an answer on here and a solution. A "POSITIVE SOLUTION" that is.
Old Mar 19, 2008 | 02:35 PM
boss1984's Avatar
this happened to me about a month ago and took my buddy and i about 6 hours to fix..mustang heads will fit your truck..the helicoil i used threaded down 10 threads on the head. and it holds great..did you use any loc-tite on the coil or sert so it wouldn't back out the head..??
Old Mar 19, 2008 | 08:15 PM
sawman's Avatar
New wires same time as plugs, about 30-40,000 miles ago. The thread repair kit i got said to use silicone gasket sealer. loctite would have probably been better.
Old Mar 19, 2008 | 08:35 PM
JMC's Avatar
JMC
25 Year Member
Did you change the corresponding plug wire? I might have been damaged upon ejection of the plug. The wires were not designed to be pulled or stretched.
Regards
Jean Marc Chartier
