Buy 5w-20 in bulk?
IMO if you have 50,000 + miles on your truck moving from a 5-20 to 5-30 would not hurt a thing. The difference between the two is minimal. I am running 5-30 synthetic in mine with 90,000 km (56250 miles) with no issues. It seems quieter at start up to me. Lots of guys here run the 5-30. I have seen threads saying ford only switched to the 5-20 as a way to get more fuel economy and that it didn't work. Just my thoughts.
Perhaps I'm overlooking the obvious....
Why not cheat a little and simply change the oil on both vehicles at the same time? This moves the change time from 6 weeks to 3-5 months. In addition, why not stock up on a few 5 qt jugs of oil when Walmart _does_ get it in? Six jugs would last 6-10 months and would be less expensive then single quarts.
Also, if you're only driving a vehicle 12k miles a year and don't usually have short hops, you could go 5 months between changes instead of 3. That would save a _lot_ of money. Of course, this part is up to you. Ford change the intervals on 2007 and newer vehicles.
Anyway, for the record, I'm knocking on 30K's door and I've been using 5W-20 Mobile 1 since the first oil change and have had no reason to be unhappy. I go via the manual's recommended change intervals.
If I do still have the truck at 60K and beyond, - I highly doubt it - I do plan to switch to 5W-30 from thereonin.
We'll see...
Ford went to 5w20 because of the tighter fit on the piston. The manufacturer found a way to increase the silicon content in the metal for this. It also is good for reduced emissions since there's less chance for unburned hydrocarbons to get down to the top ring. 5w30 is for the V6 engine so that it can linger longer and pick up more heat that the engine is producing. I use a 5w20 full synthetic that I run for many thousands of miles before changing. Synthetics have proven to increase horse power during dyno tests.
Originally Posted by Klitch
rumor i heard was 5-30 was hell on the 5.4L's ?
I'll have to say that's the first time I've ever heard that one. So what about all the people prior to '02 running "factory recommended" 5W30 in thier motors. There's also A LOT of people running 5W30 after that also!! I got caught up in all the hype that 5W20 was too thin and I've been running 5W30 for 80,000, 100% trouble free miles now!!
Ford went to 5W20 for fuel economy reasons. That's also why they backwards recommended it for the older 5.4L motors. Nothing was new about the '02 5.4 motor when they switched.
I have seen UOA's where 5W40 was used in a 5.4l and the wear numbers are excellent. Not to give anyone here a reason to go thicker, just to put the tighter tolerance theory to rest.
Bulk Oil
You can also go to www.amsoil.com and order there synthetic oils. I have used them in my vehicles for about 7 years now and they work great. They also have extended run oils in most viscosities including 5w-20, And they also have filters and all kinds of other products. If you become a member you get a better price and all oils can be ordered in bulk. Oh and they are all made in the good ol USA. So you can help out an american company selling american products. Good luck.
5w20 = 5 summer 20 winter wieght oil
5w30 = 5 summer 30 winter wieght oil
You can do the rest of hte math. 5/20 costs more. I run 10w30 synthetic in mine, 110K miles no leaks no taps rattles or pings. Sams is the best place to buy in bulk, cases of mobil 1 usually run about $29-$32 here. Walmart sells the 5 quart jug for $26-$27, but there is usually some asshat who buys it all up, like me!
urine makes about the same level of protection as Amsoil.
Mobil 1
goes in the wife's car because she will get a new one after this lease is up. I run Amsoil exclusively in my truck. We had them as a sponsor on the race car and the maintenance levels were longer with them. Say what you may but Amsoil beats Mobil 1 in tests but don't get me wrong I would use it if my local supplier quit stocking it.
