Factory Engine Specs
Old Mar 5, 2008 | 10:46 AM
02SCSB5.4L4x4's Avatar
I've got an 02 5.4L (2-valve). Does anybody know, or know where to find, extremely detailed engine specs?
cam lift
cam duration-advertised + @ .050"
intake centerline
head flow @ max valve lift
etc.
Basically as much info as possible and as detailed as possible. Thanks.
Old Mar 5, 2008 | 10:55 AM
JMC's Avatar
JMC
25 Year Member
Some of it you will find in the Helm shop manuals. You could try one of the camshaft companies. They might have the stock numbers.
Regards
Jean Marc Chartier
Old Mar 5, 2008 | 11:35 AM
joshmac4.6's Avatar
Like here is everything:
Fire order 1-3-7-2-6-5-4-8
Cylinder Head/Valve Train
Combustion chamber volume 43.95 ± 1.5 cc
Valve seat width — intake 1.3-1.5 mm (0.0512-0.0590 inch)
Valve seat width — exhaust 2.1-1.9 mm (0.0827-0.0748 inch)
Valve seat angle 45.00-44.50 degrees
Valve seat runout (T.I.R.) 0.025 mm (0.00098 inch)
Valve Arrangement (Front to Rear)
Valve stem guide clearance
 Intake 0.069-0.020 mm (0.00272-0.00079 inch)
 Exhaust 0.095-0.045 mm (0.0037-0.0018 inch)
Valve head diameter
 Intake 44.63-44.37 mm (1.757-1.747 inch)
 Exhaust 34.12-33.88 mm (1.343-1.373 inch)
Valve face runout (limit) 0.05 mm (0.00197 inch)
Valve face angle 45.75-45.25 degrees
Valve stem diameter
 Intake 6.995-6.975 mm (0.2754-0.2746 inch)
 Exhaust 6.970-6.949 mm (0.2744-0.2736 inch)
Valve stem diameter (list oversizes)
 Intake N/A
 Exhaust N/A
Valve spring compression pressure
 Intake (N @ spec.
 length) 720-800 N @ 28.02 mm (1.1031 inch)
 Exhaust (N @ spec.
Valve spring free length
 Intake 53.37 mm (2.101 inch)
 Exhaust 53.37 mm (2.101 inch)
Valve spring installed pressure N @ spec. length
 Intake 287.19-321.19 N @ 42.56 mm (1.676 inch)
 Exhaust 287.19-321.19 N @ 42.56 mm (1.676 inch)
Valve springs installed pressure N @ spec. length — service limit
 Intake 5% pressure loss @ 28.80 mm (1.134 inch)
 Exhaust 5% pressure loss @ 28.80 mm (1.134 inch)
Valve springs — out of square limit
 Intake 2.0 degrees
 Exhaust 2.0 degrees
Valve guide inside diameter 7.044-7.015 mm (0.2773-0.2762 inch)
Hydraulic Lash Adjuster
Diameter 16.000-15.988 mm (0.66-0.629 in)
Clearance-to-bore 0.018-0.069 mm (0.00071-0.00272 in)
Service limit 0.016 mm (0.00063 in)
Hydraulic leakdown rate a 5-25 seconds
Collapsed lash adjuster gap — desired 0.085-0.45 mm (0.0033-0.0177 in)
Old Mar 5, 2008 | 11:36 AM
joshmac4.6's Avatar
Camshaft
Lobe lift
 Exhaust 7.49744 mm (0.29517 inch)
 Intake 7.11038 mm (0.27994 inch)
Lobe lift — allowable lift loss 0
Valve lift @ zero lash
 Intake 13.01 mm (0.5122 inch)
 Exhaust 13.75 mm (0.5413 inch)
Camshaft end play 0.027-0.190 mm (0.00106-0.00748 inch)
End play service limit 0.025-0.190 mm (0.00098-0.00748 inch)
Journal to bearing clearance 0.076-0.025 mm (0.002992-0.00098 inch)
Clearance service limit
Journal diameters 26.962-26.936 mm (1.0615-1.0605 inch)
Journal inside diameter (cap assembled) 27.012-26.987 mm (1.0635-1.0625 inch)
Camshaft runout: full indicator measurement on all journals when supported on front and rear journals. (4 places) 0.03 mm (0.0018 inch)
Cylinder bore diameter
 Grade 1 90.200-90.210 mm (3.5512-3.5516 inch)
 Grade 2 90.210-90.220 mm (3.5516-3.5518 inch)
 Grade 3 90.220-90.230 mm (3.5518-3.5524 inch)
Piston
Piston diameter (Grade 2) at right angle to pin bore 90.180 ± 0.005
Piston to bore clearance (-0.005) to +0.025 mm ([-0.0002] to +0.0010 inch)
Pin bore diameter (piston) 22.008-22.014 mm (0.8664-0.8667 inch)
Pin diameter 22.0005-22.0030 mm (0.8662-0.8663 inch)
Clearance 0.01395-0.005 mm (0.00055-0.00020 inch)
Pin bore diameter (rod) 22.012-22.024 mm (0.8666-0.8670 inch)
Clearance 0.009-0.0235 mm (0.00035-0.00092 inch)
Ring groove width
 Top 1.53-1.55 mm (0.0602-0.0610 inch)
 Intermediate 1.52-1.54 mm (0.0598-0.0606 inch)
Oil control 3.030-3.050 mm (0.1192-0.1201 inch)
Piston ring gap
 Top 0.13-0.28 mm (0.0051-0.110 inch)
 Intermediate 0.25-0.40 mm (0.0098-0.0157 inch)
Oil control 0.15-0.65 mm (0.0059-0.0256 inch)
Crankshaft
Main bearing journal diameter 67.483-67.503 mm (2.657-2.658 inch)
 Maximum out-of-round 0.0075 mm (0.00030 inch) between cross sections
 Maximum taper
 (straightness) 0.004 mm (0.00016 inch)
Runout: FIM of center journals when located on front and rear journal 0.05 mm (0.0020 inch) (3 places)
Clearance — crankshaft journal to main bearing clearance 0.048-0.024 mm (0.0019-0.0009 inch)
Connecting rod journal diameter 53.003-52.983 mm (2.087-2.085 inch)
 Maximum taper 0.004 mm (0.00016 inch)
Crankshaft end play 0.075-0.377 mm (0.0029-0.0148 inch)
Connecting Rod
Big end journal inside diameter with assembled liners 53.049-53.027 mm (2.0885-2.0877 inch)
Rod bearing to journal clearance 0.064-0.026 mm (0.00252-0.00102 inch)
Pin bore diameter (rod) 22.024-22.012 mm (0.8671-0.8666 inch)
Rod length (centerline bore-to-bore) 169.1 mm (6.66 inch)
Alignment
 Bore-to-bore Max. twist ± 0.05 mm (0.0020 inch)
 Bore-to-bore Max. bend ± 0.038 mm (0.0015 inch)
Side play (as assembled to crank)
 Standard play 0.300 ± 0.175 mm (0.0118 ± 0.0069 inch)
Old Mar 5, 2008 | 11:50 AM
Thanks guys.
