Help!!!!!!!!!!!
Old Mar 2, 2008 | 12:42 PM
TheTamaleKing's Avatar
Angry Help!!!!!!!!!!!
I talked my dad into buying a K&N Cold Air Intake for his f-150...... I hooked it up according to the directions but now when i put the key in the ingination the check engine light and a (!) light will not go of and when i try to start it it cranks then dies.......im in need of help post back PLZ................
Old Mar 2, 2008 | 12:47 PM
jonamond's Avatar
Check all your connections. Its likely that You just forgot one of the connections
Old Mar 2, 2008 | 01:28 PM
jbrew's Avatar
Did you disconnect the battery first?
Old Mar 2, 2008 | 01:30 PM
built54's Avatar
i put my key in the ignition and the cel comes on... that is normal. did you plug the MAF sensor back in?
