truck stutters/missin
Old Feb 23, 2008 | 09:36 PM
984x4-5.4's Avatar
please help. 98 w/5.4 189thousand miles. out of the blue the truck has started to stutter and miss , it only happens while driving. it idels fine and no check engine light or codes thanks for any ideas
Old Feb 23, 2008 | 09:38 PM
joshmac4.6's Avatar
When? Light throttle, heavy throttle, cruise? Any recent mods? When was your last tune up?
Old Feb 23, 2008 | 10:54 PM
jbrew's Avatar
Update your coils(it's time).. It's only $75 now for a set of 8. For almost 2 years people on this site have had good luck w/Kevins (link)and make sure you have Motorcraft plugs in their. You will most likely go another 100,000 before this happens again
Here yuh go - http://cgi.ebay.com/ebaymotors/NEW-I...mZ160211204789
If you need plugs , there usually cheaper locally. But, if you want to order Motorcrafts On line , the cheapest I seen was @ Rock Auto.
Old Feb 24, 2008 | 07:31 AM
984x4-5.4's Avatar
motor was rebuilt 15-20 k miles ago by a mercury mech. all motorcraft stuff used. also this happens at anything above idel. could I have gotten a bad c.o.p.within those miles? thanks
Old Feb 24, 2008 | 11:33 AM
joshmac4.6's Avatar
It's possible, do you have access to a scan tool or code reader? I know the light isn't on, but it could be stored in memory. You will have to find out which cylinder is misfiring.
Old Feb 24, 2008 | 09:30 PM
984x4-5.4's Avatar
small update: cleaned throttle body,still no help question, can autozone/advanced pick up a code without a check engine light? second how hard is it to do the c.o.p.s for a first time person, I have all the tools and mehanical exp. on chevy 350s and such. man I wish this was a 83 carb'ed chevy thanks ya'll
Old Feb 24, 2008 | 09:34 PM
joshmac4.6's Avatar
You can take it to them and see, they usually don't charge to pull codes. The coils are not hard, just one bolt and a connector, the main problem is working in the tight spots. When you reinstall don't forget to put di-electric grease inside the boots, where the plug goes in.
