Terrible Gas Mileage
Hello, this is my first time posting. I have a 2000 F-150 4.6L with 103,0000 miles. About a couple of months ago, my gas mileage dropped from around 14 miles per gallon to 10/11. There have not been any errors codes; It runs fine. The only thing I have noticed is that I have to give it gas when I first start it otherwise it will die, especially when it is cold. Any ideas? Thanks!!!
It's the Winterblend fuels... and the cold. I'm still around the 20 to 22 mpg mark... but I got 22.8 mpg the other day for about 150 miles on semi-hilly terrain.
The most I've ever gotten was 23.4 mpg, and that was on a flat stretch of road, for about 35 miles doing 55 mph with cruise and defrost on.
For some reason my latest stats are 18.8 mpg... but that because of the 100% city driving I've been doing... which for a 6000 lb truck... that's damn good.
The worst my truck has ever got was like 16.2 and that was because I put premium unleaded in. Won't do that again.
Its the cold that does it more than anything. Winterblend fuel is more of a myth to be truthful, a buddy of mine in the oil business says theres so little difference its really not that much, just the fact of the winter temps.
Winter gas, and with that many miles I'd say clogged cats.
Had the same problem with my 1999 4.6. MPG dropped from 15 in the summer to 11-13. Gutting the kittys helped a lot.
As for the dying problem, I had that too when I first bought the truck. Try cleaning the throttle body. That should help some with the MPG too.
Originally Posted by 98f150guy
Zaairman, how do you go about "gutting the kitties"??
Originally Posted by jward
"Clogged cats"....Good Lord!
Zman, PLEASE quit posting that BS!
Zman, gutting the catalytic converters is just plain bad advise. Stop giving it. Your pet answer is "clogged cats". You didn't have clogged cats, you've never seen clogged cats, and most likely, you never will.
Regardless of what increase in mpg YOU'VE noticed after gutting them, you're just covering up another problem. And creating more, to boot.
The OP does not have clogged cats. Should he, or anyone else, take your ill advise and gut theirs will only create more problems. And in some cases could be breaking the law.
Save your bad advise for the General Discussion forum. It blends there.
