Running perfect. Then shuts down. HELP!!!
Old Feb 18, 2008 | 09:15 AM
Mr. Cracker's Avatar
Ok guys I need some help. My 99 F-150 5.4 runs like brand new and then completely shuts off going down the road or sitting still. Put it in park, turn the key and it cranks up like new then does it again just down the road. Anybody have any idea what this is? No sputtering. Just perfect or nothing.
Old Feb 18, 2008 | 09:38 AM
R1Jester's Avatar
If it completely shuts off, no sputtering, then it sounds electrical. What kind of, if any maintenance has been done? (battery, alternator, etc....) Possibly a bad ground or Batt wires?
Old Feb 18, 2008 | 09:52 AM
david@bonesenterprises's Avatar
Former Sponsor
Yeah that is sorta of wierd?????? Can you give a little more info. On how anything else?
Old Feb 18, 2008 | 09:57 AM
Dont think its batt. alt. or ground because it never loses radio, lights, etc.. Not sure. I bought this truck new and have always done everything myself. 163,000 miles. Because of the perfect or nothing I am lost. I am sure its electrical but no check engine light or anything that gives me a clue. I did read in my manual that it will shut itself off in certain situations but I see or feel nothing obvious.
Old Feb 18, 2008 | 10:31 AM
R1Jester's Avatar
So the entire truck doesn't completely shut off, just the engine dies? i.e. your radio is still on but the truck stopped running?
Old Feb 18, 2008 | 10:33 AM
yes exactly.
Old Feb 18, 2008 | 10:59 AM
R1Jester's Avatar
I'm kind of at a loss for this one, have to wait for some others to wander through here. Jbrew, bluegrass? Any ideas?
I'll ask the obvious, you've changed the fuel filter? Not sure how you test the fuel pump, but I'm guessing that is OK? Just because there is not CEL, there could still be some "soft codes" I believe. Might not hurt to try and get a reading see what is there.
Old Feb 18, 2008 | 11:01 AM
ok. Thanks for the feedback Jester.
TheCure's Avatar
double check your fuses and especially your relays in the engine bay, and thier connections.
Old Feb 18, 2008 | 02:33 PM
JMC's Avatar
JMC
25 Year Member
When you restart do the gauges sweep? Do you have any modifications done to the truck?
JMC
Old Feb 18, 2008 | 03:29 PM
Former Sponsor
Well im going to start by thinking the relays for the ecu????? This is a long shot.
Old Feb 19, 2008 | 09:37 AM
jerzpilot's Avatar
put a cold damp cloth on top of your distributor and run to see if your distributor is getting hot.
Old Feb 19, 2008 | 09:40 AM
JMC's Avatar
JMC
25 Year Member
99 5.4 doesn't have a distributor.
Old Feb 19, 2008 | 09:42 AM
JMC's Avatar
JMC
25 Year Member
Still need to know if the gauges sweep on restart. Becasue if they do it is a sign the the PCM is resetting so it is loosing power or has a faulty ground. If not it is one of the critical sensors that is going out and killing the engine.
JMC
Old Feb 19, 2008 | 11:35 AM
MitchF150's Avatar
How long has it been since you pulled the cables off the battery and wire brushed them?
I'd get one of those battery post/clamp wire brushes and give them a good scrubbing... If it still does what it does, then at least you know you have good contact at the source..
Good luck!
Mitch
