I Need Major Help
Old Feb 13, 2008 | 11:13 PM
chris777888's Avatar
I Need Major Help
Lately my truck's gas pedal has been sticking (I accelerate and it just stays acclerated when i release it). It does not happen eveytime I drive only a fraction of the time. I realize that the problem is with the throttle valve/throttle body but im not sure why it is doing this. Has this ever happened to anyone before and does anyone know how to fix it?
Old Feb 13, 2008 | 11:16 PM
jbrew's Avatar
Clean it
Old Feb 14, 2008 | 12:27 AM
JMC's Avatar
JMC
25 Year Member
After you clean it. Is the carpet/floor mat in the way? Missing a return spring?
Dirty throttle body?
JMC
Old Feb 14, 2008 | 09:26 AM
Hitched_Gibson's Avatar
Get under the hood and see what's sticking when the pedal is pushed, then like above, clean it.
Old Feb 14, 2008 | 09:57 AM
shifty_85's Avatar
my 97 did the same thing the pedal was getting stuck under the carpet mat. pretty scary stuff.
Old Feb 14, 2008 | 10:16 AM
malexander52's Avatar
What year
You just had two of the most knowledgeable guys on the site give you advice and IMO you should definitely follow it. Is the pedal returning to you while the truck accelerates or is it staying on the floor. I know you said release but I wasn't sure what that entailed. Pull that plastic manifold cover off and look at your spring. Do you have an open air induction or anything? I am just trying to figure out how the spring would get so dirty, or perhaps it just crapped out. Let us know what you find.
Old Feb 14, 2008 | 10:19 AM
his info up top say 2001. I know my 03 was cable.
Old Feb 14, 2008 | 02:00 PM
Yeah, as Gibson said, it is a 2001. The pedal isnt getting hung up on the carpet because I have pulled the pedal back with my hands and it just keeps accelerating. Ive also noticed that after I shut off the motor the pedal will unstick about 20 minutes later.
Old Feb 14, 2008 | 02:14 PM
The throttle plate is probably binding in the throttle body due to crud or misalignment.
Old Feb 14, 2008 | 02:15 PM
Completely different, but I had an ATV stick wide open(not fun). There was dirt being pulled into one of the cables and it jammed.
