swap a 4.2 with something else
Old Feb 13, 2008 | 10:32 AM
anthonyrapitis's Avatar
how hard and would it be worth doing? i blew my 4.2 with a coolant leak and might consider swapping to a different engine. any input would be appreciated. my truck is a 98 2wd
Old Feb 13, 2008 | 10:41 AM
tech-doc's Avatar
If you were happy with the 4.2 I would just go to the U-PULL and find a low mileage one and slap it in there. It will cost you less in the long run.
If you insist on getting a V8 in there, I would look around and see if you can't find an entire wrecked truck. That way you will have motor, tranny, harness and the PCM right there.
Old Feb 13, 2008 | 11:16 AM
i dont want another 4.2 so if i wanted to put in a v8, id need a new tranny and everything? what about mounts and stuff? any body work involved?
Old Feb 13, 2008 | 11:32 AM
tech-doc's Avatar
I will be honest and say I am not sure about the tranny. I do know that you will have to have the motor mounts, PCM and the wiring harness changed out. I'm sure sooner or later someone will chime in about the tranny.
No body work would be involved unless a fender gets smashed in while changing everything out. LMAO
Old Feb 13, 2008 | 05:56 PM
JMC's Avatar
JMC
25 Year Member
Lucky thing that yous is a 98. if you put in a triton, 4.6 or 5.4 you will need the PCM and harness, complete engine, tranny and engine mounts. Find a 98 5.4 and slap it in. The exhaust will also need to be tweeked to fit the new position of the exhaust manifold collector brought about by the taller V8 engine.
JMC
Old Feb 13, 2008 | 06:03 PM
AlfredB18's Avatar
Toss in a rear axle in the case of a 5.4L to what has already been mentioned. Then reflash the truck when the swap is done.
To go to all that work and not put the truck to use is...unwise. The 8.8 tolerance is probably just over what a 4.6L will put it through.
Unless you get a really smoking deal, get a newer v8 truck.
