Homemade E-Fan
Old Jan 30, 2008 | 07:52 PM
Jeff2005F150's Avatar
Homemade E-Fan
I have decided instead of paying a couple of hundrend dollars to buy an e-fan I would make my own.
I went to the local juckyard picked up a dual efan out of a 97 stratus. $25
I picked up a sheet of 22 gauge satin finish metal to make a shroud $20
And I picked up an E-fan adjustable thermostat at the parts store for $45
I took the fans apart and cleaned them all up and repainted them and then made sure they work which they do. I plan on painting the shroud some time over the weekend.
And this is what I came up with so far. I need to wait until the weather gets alittle warmer before I can actually install it in the truck. (sorry about the quality)
Old Jan 30, 2008 | 08:09 PM
chapdog's Avatar
Looks really good.
Old Jan 30, 2008 | 08:56 PM
NYfordguy's Avatar
I'm very interested in the shroud, thats what I'd like to do with my efans, how did you bend it? For size and mounting I plan to duplicate the OEM shroud style.
Old Jan 30, 2008 | 09:23 PM
twintips_17's Avatar
You can use a sheet metal break to do it. Looks great. Awsome job.
Old Jan 30, 2008 | 09:37 PM
I used a sheet metal brake just as twintips_17 said to bend the metal.
For the measurements the rad on 05 measures 32.5 across and 17.5 up and down. I just made a square frame with those measurments and my fan measured 24 across and 15.25 up and down. I made another piece with the first measurments and tapered it down to the fan measurements.
I could make a detailed listed if anybody wanted one.
Old Jan 30, 2008 | 09:46 PM
I think there would be a lot of people that would want that!
Old Jan 30, 2008 | 10:18 PM
s1037s's Avatar
nice
Old Jan 31, 2008 | 07:29 AM
DIHLON's Avatar
Did you check to make sure they will pull the required CFM so your truck won't have overheating problems? I imagine you did, but just thought i'd ask just in case.
