Fan Removal
Old Jan 28, 2008 | 09:19 AM
mrpositraction's Avatar
Fan Removal
How the heck are you guys getting your fan off? I tried twice this weekend and I just can't get it off. The pulley is turning in belt when trying to turn the nut that connects the water pump to the fan clutch.
I am ready for some ideas. I got my intercooler stuff mounted for my Roush S/C but can't get the fan off.
Thanks,
Greg
Old Jan 28, 2008 | 09:54 AM
shifty_85's Avatar
what i did was got a really long punch and put it on the nut of the clutch fan and hit it and it broke loose and i could hand twist it off.. after 5-6 hours of trying with a wrench i wacked it with the punch and it came right off
Old Jan 28, 2008 | 10:30 AM
Thanks, I may have to try that if I can't get it off.
Old Jan 28, 2008 | 10:46 AM
JMC's Avatar
JMC
25 Year Member
A long flat screwdriver between to of the water pump bolts and the shaft will keep the fan from turning while using a wrench on the fan nut.
JMC
Old Jan 28, 2008 | 11:55 AM
JMC
I tried that, it just broke my screwdriver.
Old Jan 28, 2008 | 11:59 AM
jbrew's Avatar
If you can't get it off - Auto Zone will rent you the tool to do it. It takes a couple custom fan wrenches to get it.
Fan Clutch Holding Tool
Fan Clutch Wrench
1. Use the fan clutch holding tool to hold the water pump pulley steady.
2. Use the fan clutch wrench to remove the fan blade and the fan clutch
Old Jan 28, 2008 | 12:02 PM
ScottFF00's Avatar
remember the fan has reversed threads.
Old Jan 28, 2008 | 12:11 PM
Toyz's Avatar
they look a bit like this
Old Jan 28, 2008 | 12:15 PM
jbrew's Avatar
Nice!!
Old Jan 28, 2008 | 12:21 PM
Matts ford's Avatar
i use an air hammer and special wrenches for it to take the fan off.
Old Jan 28, 2008 | 12:59 PM
I will check out Autozone. I went to Orielly's but their fan removal tool didn't fit mine. So I am assuming the large holding tool will slip over the outside pattern of the 4 pulley bolts and then the long wrench is for turning the large center nut?
Old Jan 28, 2008 | 01:01 PM
autozone has em. i know it says they are for the old 4.9 I6 ford motor but they work great!
If you need even more torque to bust them loose you can put a ratchet or a break bar in the square holes at the end of the wrench
Old Jan 28, 2008 | 02:03 PM
Picked up the kit at Autozone during lunch, looks like it will do the trick. If the rain holds out I will attempt it tonight.
Thanks,
Greg
Old Jan 28, 2008 | 03:01 PM
NYfordguy's Avatar
I second the punch idea, long piece of solid steel bar stock and a little PB blaster and she came off like butter, used a rachet to hold the pump pulley fairly steady by one of its bolt heads.
Old Jan 28, 2008 | 03:17 PM
GIJoeCam's Avatar
Not usually.
The easy way to know which way to turn it is whichever way the fan spins when it's running. Otherwise it would unscrew itself in normal operation.
