Who's valves rattle?
Well, I'm now in the 100K club. For the past couple of months (or more) I've noticed my valves chattering when the truck's in a lug. Down shift and it's fine. Can my valves be adjusted? 03, 4.6 by the way
Sounds more like detonation to me... I don't know that I have ever heard valve "rattle". If there is enough slop in your valve train for them to "rattle" then I would guess you need to re-work the entire heads.
Just my $.02...
Just my $.02...
What could be the cause of this detonation then? It idles around 600 rpms and if I hit the throttle really quick then it will dip down (with that quick rattle) then go back up. It does it with higher octane fuel as well.
Any ideas?
Any ideas?
Originally Posted by built54
probably detonation
If he is floating the valves at idle... i cant imagine how it runs above 1000rpm......
CDB03STX - That is a perfect description of what mine does. Also going up hills it will do it if i blip the throtte. But not all the time tho. It needs great tho. Could this detonation be due to bad gas or not high enough octane? Could my intake cause this condition being that is does have a tune?
Built - It runs great over 1000 rpms. Seems like I have a clutch that Im lettin it out too soon.
