Cam question
Old Jan 21, 2008 | 08:12 PM
Raatikainen22's Avatar
Cam question
how do i get my truck to sound like this:
http://www.youtube.com/watch?v=8HVmjuuSFDw&NR=1
and by installing a new cam what pro's and con's are there?
Old Jan 21, 2008 | 08:52 PM
torkum's Avatar
Put a chebby 350 with a crane fireball cam and a holley 650 double pumper and you got it Thats old school
Old Jan 21, 2008 | 09:23 PM
built54's Avatar
you cant... with a good tune, even the biggest cams sound mild. You cant even hear my stage II custom grind cams because my tuner knows his ****
Old Jan 21, 2008 | 10:55 PM
JMC's Avatar
JMC
25 Year Member
The amount of overlap is what causes your "rough idle". You can figure this with this equation: Intake duration + Exhaust duration, divided by 4, - LSA ( LOBE SEPARATION ANGLE) , x 2. The more overlap, the rougher the idle.
Stock
202 + 207 = 409 divided by 4 = 102.25 - LSA112° = -9.75 No overlap, no lope
COMP CAM XE262H
226 + 230 = 456 divided by 4 = 114 - LSA113° = 1° Almost no overlap no lope.
CROWER 62804-2
246 + 246 = 492 divided by 4 = 123 - LSA113° = 10° This cam should be a little rough. It could be mistaken for a miss.
JMC
PS. I am not positive on the LSA of the CROWER but I believe it is somewhere between 112 and 114.
Old Jan 21, 2008 | 11:16 PM
stein78's Avatar
Not sure I agree with you. It's all in the cam profile on how it's going to sound. Some grinds just don't lope like others.
Here are some Comp 278s in my 2V mustang, my tune is on the money. You can kind of hear the cams.
http://www.modularmisfits.com/forums...firststart.wmv
One should never buy cams just because they sound good. If I put the cams from my mustang into my truck, I would have no low end torque/power at all. You want the right cam for your application.
Old Jan 22, 2008 | 08:32 AM
built54's Avatar
oh yeah i've heard plenty of lightnings with the same gring cams I have, and they lope like crazy, I wish mine did, but then again,everyone thinks its stock.
Old Jan 22, 2008 | 04:32 PM
Stock
COMP CAM XE262H
CROWER 62804-2
JMC
Sounds like you know your stuff!! i was just wondering if i were to switch out my stock cam to an aftermarket one would it sound like this and if i would gain/lose anything valuable..like say torque..
Also, if there is a good switch from stock to aftermarket which one would be a good suggestion?
Thanks in advance!!
-Alex
Old Jan 22, 2008 | 04:58 PM
stein78's Avatar
Not sure what year truck you have, but if you have a 4.6 or 5.4 engine you have cams - two of them.
Crower and Comp make some good cams for the modular engines. Some of their cams are truck specific and provide a decent torque improvement over stock. Check out their websites for the info.
Old Jan 22, 2008 | 06:54 PM
Faster150's Avatar
they just set their idle lower.
Old Jan 22, 2008 | 06:56 PM
Faster150's Avatar
stage 3's lol nice
my cams only have about 4degree of overlap.
Old Jan 22, 2008 | 10:22 PM
built54's Avatar
My idle is 650. at 600, it still sounded the same.
