4.6 redline?
4.6 redline?
Does anybody know what the redline is on a 1997 f150 with a 4.6 because I have a superchips programmer and i bumped it up from shifting at 5000 to 5700 and I really don't want to blow it up but I want the most performance I can get.
I would say in 3rd(for racing) or OD(for breaking the sound barrier) you can go up to 5500 or even 6000 .
But your 1-2 shifts should be about 54 to 5500. That's about the limit of your power-band. After that your just wasting time!
Phil
Phil
Your 4.6 will not go to 6000 in third unless you do some major mods to the engine.
I have a 5 speed and I had the rev limiter set to 6500 when I had the 4.6. My 97 was set the same way. No ill effects on the motor. But with an auto you are best to dial it back to 5500 at the most till you beef up the tranny.
JMC
I have a 5 speed and I had the rev limiter set to 6500 when I had the 4.6. My 97 was set the same way. No ill effects on the motor. But with an auto you are best to dial it back to 5500 at the most till you beef up the tranny.JMC
Thanks yeah it doesn't seem like it has much power after 5500 rpm so ill probably have it shift at 5500 rpm
Originally Posted by built54
you will be fine, but i wouldnt go past 5500
