Project BULLETPROOF...dream or reality?
Old Jun 12, 2008 | 05:32 PM
  #406
jbrew's Avatar
Originally Posted by Jackal
I posted it just a few posts ago.
You can see where it tapers down from 2 1/2" to 2 1/4", then down to I believe 1 7/8".
Yea , I seen that "Black Hole" pic - Can't really tell what that was. I had a few thoughts cross my mind , similar to tech-docs
At least I gave you a better picture of it - Anyway - YUP! Mines more bettuh - It's just as smooth inside - as the out.
Old Jun 27, 2008 | 12:58 PM
  #407
Jackal's Avatar
Evar get that tharr EGR fancied up?
Old Jul 18, 2008 | 12:11 PM
  #408
Jackal's Avatar
Figured out what the occasional popping noise was after the gear install. Rear U-joint is SHOT...lots of slop. Front seems fine. These were AC Delco (I know, that's the problem right there) Super Duty serviceable u-joints that I put in about 30K miles ago and serviced them every oil change. They had the needle zerk in the end of 1 endcap rather than having the normal zerk in the middle of the joint...supposedly stronger.
...so, any idea why the premature failure? Should I have the driveshaft balanced? What u-joints should I go with this time? Any reason to switch to an aluminum shaft? They're $100 at the junk yard.
Old Jul 18, 2008 | 12:36 PM
  #409
JMC's Avatar
JMC
25 Year Member
What failed on the U-joint? The needle bearings? Is the yoke cracked? If it is just the U-joint just get a better brand. I always have the shaft rebalanced after new U-joints. They can check the shaft for true and cracks while it is being balanced. I see no reason to switch to an aluminum shaft other than a weight savings.
Regards
Jean Marc Chartier
Old Jul 18, 2008 | 01:10 PM
  #410
Jackal's Avatar
Looks like broken / possibly somehow missing needle bearing(s). Any recommendations on replacements? How much you payin for balancing? Thanks man.
Old Jul 18, 2008 | 03:34 PM
  #411
Jackal's Avatar
Found 2 local shops that will do Spicer u-joints, parts, labor, and balancing for $100 - $150 if I bring them the driveshaft. Question is, do I want Spicer u-joints...
Old Jul 18, 2008 | 03:50 PM
  #412
tech-doc's Avatar
I would do it if it were mine. That isn't too bad of a price, considering labor charge now days...
Old Jul 18, 2008 | 06:27 PM
  #413
Blown F-150's Avatar
Sounds like a good price, I went with MOOG u-joints last time and they have lasted over 80kms. They come with a lifetime warranty.
Just my 2 cents
Old Jul 18, 2008 | 09:11 PM
  #414
jbrew's Avatar
Yea, Egr fixed - Those BIG Troyer high flows welded directly onto the headers now. Problem was , the cat and header together were 2 1/4" to long and you can't have that on a 4x4. - I had to chop the front of the cats 2.5 ID flang off / notched the heat shields back so I had the room to run a bead around a 3"OD replacements. Should have purchased the barrel HF's instead.Took about 3/4" off the 3" ID LT Flange. Everthing is welded solid all the way back to the tailpipe. Next time the system needs to come off - It's goin in the garbage..
Old Jul 24, 2008 | 10:41 PM
  #415
Jackal's Avatar
Got the driveshaft back today with non-serviceable Spicers, but they look beefy as hell and I think are the Lifetime Extended Service parts. Anyway, still have some sort of issue I posted here:
https://www.f150online.com/forums/sh...d.php?t=340395
Old Mar 10, 2010 | 11:15 AM
  #416
Jackal's Avatar
Alright, it's about time to "finalize" this bad boy...the only thing left (aside from a blown 5.4 conversion) is to do the full body Line-X encasement.
Love it or hate it, it will be different. No more waxing or worrying about dents / dings, or scratches. It will add about 120 lbs., but that's nothing. I've taken more factory parts off of it than that I'm sure. Also, I'm talking Xtra here, not the standard bed coating that looks like dog shat after a year. If you have any personal experience with Xtra, good or bad I want to hear it.
I have been trying to decide which way to go with it. I considered just spraying the tailgate, roof, hood, and rocker panels in black or a really dark charcoal. Then I thought about charcoal racing stripes and rocker panels. Today I'm back to full body spray, but can't decide on color.
I figure if I'm going to drop this kind of coin on a 10 yr. old vehicle with 88k mi. on it, I should change the color too. What do you guys think?
- All black Xtra, EVERYWHERE
- All dark charcoal Xtra, EVERYWHERE
- Metallic charcoal
- Charcoal body with black fender flares, maybe rocker panels and other accents
Here is a link to several very much dated pics of my truck...feel free to photoshop if you're sitting at work getting paid to be bored.
http://s493.photobucket.com/albums/r...ackalAR/Trucks
Here is a gallery of vehicles with Xtra on them done by a site sponsor:
http://www.linexfortworthtexas.com/photogallery.htm
Here is a sample of what the texture would look like:
Old Mar 10, 2010 | 11:32 AM
  #417
JMC's Avatar
JMC
25 Year Member
Will the underside be done too?
Old Mar 10, 2010 | 12:08 PM
  #418
Jackal's Avatar
Probably not...don't you basically have to strip it down to the frame for that?
Old Mar 10, 2010 | 01:17 PM
  #419
jbrew's Avatar
Don't do it, your truck looks good the way it is. Concentrate on the blown 5four
Old Mar 10, 2010 | 01:30 PM
  #420
Jackal's Avatar
Damned voice of reason.
