engine missing
Old Jan 14, 2008 | 11:50 AM
rustyrumley's Avatar
engine missing
I have a 99 ford f150 with the small v-8. The engine will misfire at about 1800 RPM'S with any slight load. Any ideas?
rusty
Old Jan 14, 2008 | 11:56 AM
KTrostel's Avatar
When this happened on my '01 5.4 it was the COP on the #1 (driver side front). Moisture (especially from the radiator hose connection) gets into this location and kills the COP. It could be other COPs but on mine it happened twice to the #1 COP.
Have your OBDII scanned. Even if the CEL is not on you probably have thrown codes (AutoZone does it for $0).
Old Jan 14, 2008 | 12:00 PM
What is the COP? Is that the coil pack for the spark plugs.
Rusty
Old Jan 14, 2008 | 12:01 PM
kasparsport's Avatar
Im going through the same thing right now....I had the plugs & wires done now it actually runs worse....a few people from this board suggested a coil pack went bad....a check engine light finally came on so Im gonna get her scanned to see if they pin-point any one thing....
good luck....
Old Jan 14, 2008 | 12:05 PM
jbrew's Avatar
https://www.f150online.com/forums/sh...d.php?t=264844
Old Jan 14, 2008 | 12:15 PM
Thanks I will check them.
Rusty
Old Jan 14, 2008 | 12:17 PM
jbrew's Avatar
No Problem .
Good Luck
Old Jan 14, 2008 | 02:54 PM
Originally Posted by jbrew
No Problem .
Good Luck
I went and look at the link and saw what they look like and saw the testing process. I took a look under the hood of my truck, my truck has 2 coil pack one for each bank. Do you know of any testing for this type.
rusty
Old Jan 14, 2008 | 02:59 PM
jbrew's Avatar
Same to Test - Follow procedure . Drive cycle test - hold @ misfire.
