First Start After Oil Change Is Rough ??? (2004) - PLease Help???
Old Jan 11, 2008 | 02:42 PM
JasonFX4's Avatar
Originally Posted by Galaxy
Ha ha ha!! You're a complete riot!! Yes, my filter is straight up and down, so I can fill it to the brim!! And with the filter that holds a full quart, and being that far away from the engine...it makes a difference. I thought that's what/why you guys were referring to, but just checking. Even on filters mounted sideways, you can still get quite a bit of fluid in the filter medium. Every little bit helps IMO.
What set-up did you use? I want to install a remote filter for a few reasons, one to make it easy to change, two so I can use bigger filter. To me the recommended ones are too small for filtering 7 quarts all the time.
Old Jan 11, 2008 | 06:56 PM
dkstone05's Avatar
I can fill the filter to at least 3/4 full on my truck and usually don't spill a drop. Same usually goes for the wifles car, it is 100% horizontal. As long as you don't fill it to the brim the filter holds most of the oil in... you just need to be fast when you tip it.
Old Jan 11, 2008 | 08:34 PM
Bluegrass's Avatar
To the original poster:
If your oil change is with heavier oil, change to 5w20 and the pressure will come up faster, that's why 5w20 is speced for the motor.
It may not now fix anything but should help.
Another device that could be the solution, if it is cam drive related, is an external oil accumulator to pressurize the system before starting.
Few motors ever need this kind of device but once it is id'ed as the fault, it may pay to look into it.
Old Jan 11, 2008 | 08:56 PM
MeanGene's Avatar
Originally Posted by Pnewman
Your camshaft phasers are the outdated units- 2004. When the oil is drained and restarted the phasers need to refill. What you're hearing is the internal vane housing bottoming out on itself until the oil can fill the chamber back up, as well, your cam timing is way off at that time until the oil is there causing a rough running. Its a common problem and needs the 2005 phasers to be installed. Ive done countless ones here at the dealer. Typically its about 15hrs labour plus $600 in parts. If you have an extended warranty, use it.
I have a 2004 with the extended warranty and the engine will make some noise at startup, especially when cold. What can I tell the Service Dept. that would trigger them to do the work? Right now they say they can't duplicate the problem.
Old Jan 11, 2008 | 11:30 PM
Galaxy's Avatar
Originally Posted by mkosu04
is that an aftermarket oil filter setup?
If so... Whats the purpose? - mainly for easier access or better oil filtration?
Just curious...
The blue tubes make me think its aftermarket.
Yes, it's an aftermarket set-up. (but god please don't tell the guys over in the oil thread I'm running a non-Motorcraft filter that's not even the one to fit this truck ) It is not a kit. Perma-Cool and Summit (probably some others) make "ready to go" kits, but I personally think they're cheap in comparison. I made my kit myself and pieced it together. The filter base is from Peterson Fluid Systems (they make top end dry sump oil systems/pumps/components...$$$$$$$$) and the lines are all -10 Earls braided line with -10 AN fittings everywhere.
Reasons...Cooling (although minimal) from the filter being off the engine and in the air flow. Increased quantity by almost a quart due to the size of the filter and the lines. Better filtration from the size of the filter. And easy maintenance. Completely trouble free/mess free filter changes. Plus it just dang looks cool
There's more pictures of it in my gallery.
Old Jan 12, 2008 | 09:45 AM
Pnewman's Avatar
Yes, tell them when you start it in the AM that it sounds like a rod knock for a few seconds then goes away. Also tell them that when sitting at a light in gear you hear a faint knock as well. You may have to leave it over night for them to duplicate the concern, you could even toss the "cam phaser" term around to lead them in the right direction if their clueless. If it happens everytime for you but not when they have it over night you know they're BSing you and dont want to fix it. Then you'll have to take it elsewhere. Either way its covered and at most it'll cost you the $100 deductable on your ESP contract.
Old Jan 12, 2008 | 10:07 AM
jbrew's Avatar
Why do you have it easier to get to ? You only change your oil every 25K Just messin with yuh
That is a sweet set up , purdy too- Mines sort of the same way - but horizontal, try filling that one before installing.. -
Old Jan 12, 2008 | 01:08 PM
Galaxy's Avatar
Ahh yea JB, is that the stock one?? Still nice isn't it!! I have remote filters on every vehicle I've ever owned almost. I want to put one on my wifes Lexus (it's a messy PITA) but can't find a base adapter to spin on the filter pad.
Did you see that other comment I made??
Yes, it's an aftermarket set-up. (but god please don't tell the guys over in the oil thread I'm running a non-Motorcraft filter that's not even the one to fit this truck ) .
P.S. For the record, and since we're not over there in that "other" thread, I go 7,500. Yes I use and firmly believe in my Amsoil products, but I did grow up old school and some habits are just damn hard to break. I'm trying to stretch it out to 10,000, but even if I do that, that'll be it. Gonna get some Blackstone lab work done probably just for ****s and giggles
Old Jan 12, 2008 | 01:12 PM
Galaxy's Avatar
As for relevance to this thread, my '02 knocks a very little on a cold start up, and rattles pretty good for a few minutes when it's been sitting a long time. I remember discussions a long time ago in our trucks that it was a rod making some noise. Too bad it's tough to do noises over the forum!! That would help out a lot. I'd like to have my knock addressed but she's not under warranty and if I recall, guys with the pre-'04 rod knock weren't really having any detrimental failures, just the annoying noise.
you guys remember any of that?? Just curious if it relates to the '04's in any way.
Old Jan 12, 2008 | 01:49 PM
jbrew's Avatar
Thought that was "Piston Slap" ? Oh and yes , remotes are nice - I changed an 01 model out last - damn thing had me cusin in no time.. Stupid stupid stupid!! Why did Ford change the local!!????
My kids changing her oil as I post - hers is a 4.2L and it's at the bottom as well - but it's allot easier than that 01 5.4L.
Old Jan 12, 2008 | 01:53 PM
Galaxy's Avatar
That's it!! Yep!!
Old Jan 12, 2008 | 03:15 PM
jbrew's Avatar
That's it!! Yep!!
I managed to escape that problem. My 98 motor didn't have it - neither does the 98 ford Reman that was put in fall of 2000..The 4.2L doesn't and the 01 (not mine) hasn't had it either (40,000 miles)..
I know it's a common problem from the posts here, never come across it yet tho.
Old Jan 13, 2008 | 02:32 AM
chrism9232's Avatar
i want to know why you go to Valvoline and let some kid work on you truck?
