resistance in an IAC valve
Old Dec 31, 2007 | 03:59 PM
absaluteviktory's Avatar
I tested an IAC valve's continuity and it showed 10omhs resistance.....is this allowable in a 1997 4.6l f-150?
Old Dec 31, 2007 | 04:57 PM
chucks bp's Avatar
Ford service manual states the resistance should be between 6.0 and 13.0 ohms. I would say that yours is right where it should be. You also want to measure between each pin and the case of the IAC valve, that reading should be greater than 10,000 ohms.
Old Dec 31, 2007 | 05:11 PM
jbrew's Avatar
Nothing wrong with testing your IAC's continuity, but they usually don't fail electrically - They will commonly lock up when bad. The internal mechanicals get sticky from carbon deposits, rust or some other foreign matter resulting in cold start idle issues.
Old Dec 31, 2007 | 11:08 PM
that's service
thanks guys, exactly what i wanted to know.......i am going to change all plugs and wires tommorrow and replace.........noticed a popping noise like a small backfire as i try to accelerate...no codes thrown though.....
