Squealing noise
Old Dec 31, 2007 | 03:49 PM
NA660rapter's Avatar
Arrow Squealing noise
ok i just replaced my throttle body and iac valve. There is a squealing noise coming from the exhaust or tranny. It was fine before i replaced both. It doesn't squeal when its in neutral but when in drive it squeals till about 1500 rpms then goes away. i have no idea what it is anyone know??
Old Dec 31, 2007 | 05:02 PM
shaunakadub's Avatar
The first thing I think of when someone says squealing is the belts.
Give them a once over a see how they look (Shouldn't be cracked, frayed, loose, ect.).
If you discover it is the belt, I highly suggest a Goodyear Gatorback belt.
Old Dec 31, 2007 | 05:18 PM
the only thing is it sounds like its comming from the tranny or exhaust but if was perfectly fine before i changed the throttle body
Old Dec 31, 2007 | 06:27 PM
gamer565's Avatar
Stp belt dressing works great too.
Old Dec 31, 2007 | 07:50 PM
jbrew's Avatar
The only thing related to the trans would be the TPS sensor on the TB.
But , I never heard a trans squeal.
Pull the belt and start it while it's cold and see if it still squeals- that will tell you if it's a belt,idler,pully or power steering problem.
Old Dec 31, 2007 | 08:19 PM
150_Eagle48's Avatar
You might have got something on the belt whenyou took the tb off causing it to slip
Old Dec 31, 2007 | 08:34 PM
Ehhh... I strongly advise against dressing's personally.
I've seen them work good for the first few weeks, then basically act as a chemical attack on the belt, making the problem worse than it was in the first place.
Just another reason to spend the extra 20$'s and have a high-quality belt for many miles.
Old Dec 31, 2007 | 09:03 PM
Tumba's Avatar
does the sguel start gradualy and end abruptly?
Old Jan 1, 2008 | 03:21 AM
it squeals when you put it in drive and when u start driving and hit like 1500rpms it goes away and the noise isnt comming from the motor its comming from under neith
Old Jan 1, 2008 | 11:40 AM
Tumba's Avatar
that is strange enough. surely someone here has had the problem before.
did you try it without the belt?
the noise starts as soon as you put it in gear?
Old Jan 1, 2008 | 01:43 PM
ya when i put it in gear and hold the brake and push the gas it starts squealing and then when u put it in neutral it goes away
Old Jan 2, 2008 | 12:44 AM
gamer565's Avatar
havent seen any problems and ive used it about 3weeks ago
Old Jan 2, 2008 | 07:10 AM
jbrew's Avatar
So what happened when you tried it without the belt ?
Old Jan 2, 2008 | 05:21 PM
Exclamation
ok i took it back to the shop today and the rubber piece where the intake tube it pushed in was stuck in too far and the rubber piese has like vacuum hoses hooked to it . Its the rubber piese that seperates the the intake to to the throttle body. I found out that it was pushed in too far and i pulled it out a little to unblock the hose holes and fixed the squealing noise right away. watch out when messing around wiht yuour intake tube not to push it in too far to clog the two holes.
Old Jan 2, 2008 | 05:45 PM
NYfordguy's Avatar
Pinched! :-)
