98' 4.6 swap to 5.4...again !
Old Dec 19, 2007 | 11:33 AM
stevelaliberte's Avatar
I know it been discuss 1000 times... but i can't find out...all info !
so again.....
i got 98' 150 4x4 auto... want to swap to 5.4 (2006) !!!
what should i know... what model ( it come from )
wiring and cpu the same
intake... headers same
tranny... bolt right in
..... plzzz need help !!
asap
thank you
steve
Old Dec 19, 2007 | 01:15 PM
anyone !!!
Old Dec 19, 2007 | 01:20 PM
_cashel's Avatar
If you're swapping into an 04+ 5.4, you may run into some trouble. I don't know much about the swap, but I do know the newer 5.4s are slightly different.
Old Dec 19, 2007 | 01:35 PM
thank you for your reply.....but i seriously need some help !!!
Old Dec 19, 2007 | 02:21 PM
phil6608's Avatar
The swap will be way less complicated if you stick to a 99to 03 5.4
You could even put a Lightning motor in there and make BIG power.
Start with one of thees! http://www.johnnylightningperf.com/s...products_id=29
Stick a set of ported and polished heads with HP cams on there.
Then put this kit on top. http://www.nloc.net/classifieds/show...9/limit/recent
Get your self a custom tune or put a Lightning computer in there and your good to go for 5, 6 or 700 RWHP!
Phil
Old Dec 19, 2007 | 02:22 PM
jbrew's Avatar
Yea , listen to Phil
Look up user JMC then go thru his posts for the info... Your going to need the donor vehicle for that swap or it may not even be worth it.
Old Dec 19, 2007 | 05:03 PM
Klitch's Avatar
if i had more time i could find the thread on here where a guy converted the 04+ TB from electric to cable. which would be one of your headaches.
intakes definately not the same, your 4.6 has a lower deck height, 2v. the 5.4 has higher deck. (im just hitting some major probs here)
exhaust, again deck height change. the 5.4 headers needed.
you have almost a 10 year split and a motor difference. your wiring and comp are going to be different.
im not saying its impossible, just saying the headache probably isnt worth it after you look at the 5.4 lightning swaps.
Old Dec 21, 2007 | 08:43 AM
ok thank you...
but i think headhache is the less expensive way to get...fresh engine(low mileage) w/ tranny. and transfer case !!
actually here in Montreal ,canada ... area lightning.. or even harley donor... are pretty rare (and quite expensive too )
so that why im looking for... a recent 5.4...
again need help
steve
Old Dec 21, 2007 | 09:42 AM
s1037s's Avatar
Ebay? thats where i got two cheap. one sohc one dohc
