04 F150 5.4L...5w30?
Originally Posted by autobahn
There is no 5w20 Oil in Germany. All Ford uses is 5w30 and I never had any issues. Since I have the normal Ford warranty I guess there must be other reasons why Ford wants you guys to only use 5w20. But if it was availible over here i´m shure I would use it.
Mine's an '02 (not a 3v motor) but 5W20 is still recommended. I think '02 was the first year for this big debate. Anyways...5W30 user since day one and 75,000 completely trouble free miles....well, oil related anyways
Not to thread jack, but for you Amsoil fans...they have two different 5W20's and a 0W20. What's the difference between them (other than the obvious viscosity difference in the case of the 0W20) and which one do you guys use?? Wonder if they make a recommendation based on what it's being used for??
**edit** they only have the one 5W20 and the 0W20 but also have two different 5W30's and a 0W30. Wonder if one of the 5W30's is supposed to be better than the other??
If I happened to buy a new truck for some crazy reason, I would most likely switch to a 5W20. Only reason I don't in mine now is I wasn't a Amsoil user when I first got the truck and no one else had a full synthetic 5W20. I think the only thing out at the time was that Motorcraft synthetic blend...which still isn't a bad oil, I'm just a Mobil 1 fan.
Assuming that you had anything but Amsoils XL7500 put in the engine, it won't hurt the engine. All of Amsoils products are on the thin side of the viscosity range. The SAE range for a 20 viscosity is 5.60 to 9.29. Most of the Amsoil 5w-30 products will be just over 10.xx. The range for a 30 viscosity is 9.30 to 12.49. You or your engine will never know the difference as most of the 5w-20 oils at temp are 9.xx or right at the top of the viscosity range. Not all 5w-20s are the same viscosity at temp and neither are any of the other viscosities you buy. They fall into a variable range. There is nothing wrong with the oil they put in your truck. You will do no damage to the engine by running it.
Where's Norm when ya need him?
It's fine, don't worry about it. Next oil change just put in the 5-20, running a 30w for a bit isn't going to hurt anything.
My 4-stroke sled takes 0-30 oil, that stuff is like water it's so thin. But then again the Yamaha motor's ECU can adjust to run as cold as -40 degrees F, so I suppose that's necessary. My truck would be a popsicle by then.
Hey Labnerd...still curious what you meant by your comment about the XL oil???
Incorrect oil. The following is straight out of the Amsoil product selection guide as the only suitable Amsoil oils for your engine:
Take it back to the place where you had the job done and ask that they drain it and replace it with one of those 3 correct oils. They sold you the wrong stuff. What they sold you does not meet Ford specs for your engine. Will it hurt it? I doubt it, but why take a chance when you are paying that kind of price for an oil change?
http://www.amsoil.com/scripts/runisa...msoiloaf:index
100% Synthetic 0W-20 Motor Oil (ASM)
SAE 5W-20 XL Synthetic Motor Oil (XLM)
SAE 0W-30 Synthetic Signature Series Oil (SSO)
