help truck running rich!!
Old Dec 11, 2007 | 01:21 PM
goodwrench78's Avatar
Post help truck running rich!!
92 f150 5.0 running really rich of fuel does anyone have any ideas??
Old Dec 11, 2007 | 08:47 PM
TECHDOC's Avatar
Check your fuel pressure regulator, on top of the engine drivers side rear, pull the vacuum line off, if there is fuel in the vac line, it is bad. let me know if this helps.
Old Dec 11, 2007 | 10:19 PM
wde3477's Avatar
any codes? - 'check engine' light on?
Old Dec 13, 2007 | 12:26 PM
no fuel coming out of reg,vaccum line and no ses light
Old Dec 13, 2007 | 01:38 PM
TECHDOC's Avatar
O.k., rules that out. Could you try to describe the problem a little more specifically, how does it react at idle, on acceleration, cruising? How exactly do know it is running rich?
Old Dec 13, 2007 | 05:41 PM
At Idle Only! If You Have Your Foot In It, It Runs Great, No Vac Leaks, No Injector Leaks, New Coolant Sensor, Etc
Old Dec 13, 2007 | 05:43 PM
It Loads Up At Idle Only And Black Smoke, Off Idle Runs Great!
Old Dec 13, 2007 | 09:21 PM
TECHDOC's Avatar
How many miles are on the truck? Does it run smooth at a steady cruise speed? (35-40 mph). Is it hard to start at all? Is your truck M.A.F. equiped? Have you checked fuel Pressure? Last, but not least, have you checked the oxygen sensors? Sorry for the long list of questions, but without physically experiencing the symptoms, diagnosis can be difficult.
Old Dec 14, 2007 | 11:19 AM
TECHDOC's Avatar
It is also possible that the e.G.R. valve my be stuck open, you should check that also.
Old Dec 14, 2007 | 07:25 PM
Bluegrass's Avatar
The hose to the MAP sensor is faulty or the MAP it'self is bad.
