Missfire Cylinder 6
Old Dec 6, 2007 | 10:39 PM
Shedstomper's Avatar
Cleared the codes earlier today, and since then there isn't a solid light, it flashed and then went off. It usually does that a few times and then the light stays on solid.
It does it at all RPM's, but is worse under load.
Old Dec 10, 2007 | 09:16 AM
Watched the code this weekend and it has stayed the same. Is there anything else I can check to make sure it is the COPs? And is it common for them to go out close together like that? Just surprised that #1 would go out right after fixing #6.
Old Dec 10, 2007 | 09:38 AM
JMC's Avatar
JMC
25 Year Member
While the COPS may well last for over 150K the boots don't. I am still using the OEM COPS with well over 130K but the boots have been changed 2 or 3 times.
JMC
Old Dec 10, 2007 | 10:07 AM
Where can you get just the boots? I think that is my problem the boots are letting moisture in. The problem seems a lot worse when it is wet outside.
Old Dec 10, 2007 | 11:32 AM
JMC's Avatar
JMC
25 Year Member
Any car parts store should carry them or be able to order them. Napa, Autozone etc.
JMC
