engine locked up (revised)
Old Nov 29, 2007 | 12:20 PM
oilant's Avatar
Sorry it is a 1998 F-150 4x4 with a 4.6l and a 5 Speed. What is hydrolocked? How can it be fixed?
Old Nov 29, 2007 | 01:47 PM
How about replying to the existing thread?
Old Nov 29, 2007 | 02:10 PM
krazyballer's Avatar
Hydro lock is when coolant or a liquid leaks into the cylinders and when you start the motor somethings gonna happen. Im rebuilding a motor at school because of this it bent the connecting rod then when i took it apart i found out it had a cracked block. So i got a new block and started rebuilding. As far as how to fix it you just have to pull the motor apart and see if it did any damage.
