Would this fit?
Old Nov 26, 2007 | 04:22 PM
NastyNate's Avatar
Would this fit?
http://cgi.ebay.com/ebaymotors/FORD-...QQcmdZViewItem
I own a 99 F150 XLT and if I was to want to swap engines in the future would something like this fit?
Old Nov 26, 2007 | 06:28 PM
jethat's Avatar
No.
Not without major modification. New trans and transfercase custom mounts on and on. It would be just as easy to put that motor in a chevy or a dodge..
Old Nov 26, 2007 | 07:15 PM
NastyNate's Avatar
Oh ok. What type of engine would be an easy swap that is more powerful then the 5.4 that is in there?
Old Nov 27, 2007 | 02:26 PM
AlfredB18's Avatar
A Lightning 5.4L.
Relative bolt-in swap. But, I hear you need the chassis harness because the dual fuel pump plugs tie into that harness. Maybe that can be worked around, though.
Old Nov 27, 2007 | 04:44 PM
minimonster17's Avatar
that's what she said!
Old Nov 28, 2007 | 12:20 PM
KEITHHATTER's Avatar
That motor WOULD fit, BUT, many, MANY, MANY mods will have to be done.
However check this link out and see what you think. This will definitely fit!
http://www.seanhylandmotorsport.com/
Old Nov 30, 2007 | 09:58 PM
NastyNate's Avatar
Hahahaha exactly. I was just wondering about all this because I have the 5.4 triton v8 which has decent power in itself. It seems like it would be cheaper to just mod it than swap out an engine. I know I couldn't afford a lightning engine as I only have about 3500-4000 to play with right now.
Old Dec 1, 2007 | 04:54 AM
We have a member that did a V10 swap - name is camdenlake if you want to search for the thread.
Old Dec 1, 2007 | 11:48 PM
ATC Crazy's Avatar
A 460ci will fit just fine if you want to make your own engine mounts and crossmembers.
