Replace COP's with Spark Plugs?
Old Dec 17, 2007 | 05:22 AM
  #46
Muaz's Avatar
Hi, This post of mine is very knowledgable and may enhance the information of the viewers , however I would like some specific information for myself. If someone can help me then please send me a private message. Best Regards,
Property Directory | Wholesale Billiards
Wholesale Batteries |Stock Brokers Directory
Old Dec 17, 2007 | 01:46 PM
  #47
malexander52's Avatar
Global Story
I replaced my COPs Saturday night. Cylinders 4 and 8 were kind of tough but I got them out and replaced. I managed to strip the head of the bolt that holds COP 7 in place. I did NOT remove the fuel rails, I didn't need to. It took me two hours start to finish. I couldn't be happier. There is a marked difference in throttle response and the truck pulls like new! I replaced the plugs with Motorcraft plugs 10k miles ago. I also have the granatelli performance boots. The OEM plug boot has a wound spring where as the granatellis are solid/braided connectors. Anyway the truck is hauling ***** again, beautiful idle etc... I am out of town for the next week but Ill drop a few more miles on her around Christmas and get back to you guys with a follow up.
Old Dec 17, 2007 | 04:28 PM
  #48
jbrew's Avatar
Glad to here it worked out . Yea, I don't use the stock boots that came on the 99's on up.. There pretty cheap. I use the 98 boots and found and extra set on that I purchased on ebay - COP's and boots from a GT .. Sweet boots , thicker Isolaters and there make up is solid brass and copper..Hard to find ..
Old Dec 18, 2007 | 07:39 AM
  #49
Shedstomper's Avatar
Got mine on the way this weekend also. Hopefully get them on soon. Anyone know of any problems if I should have to stop in the middle and only get one side on at a time? Hopefully I can get them all switched out at the same time, but you never know. Just wondering.
Old Dec 18, 2007 | 08:15 PM
  #50
shs_bulldog's Avatar
[QUOTE=malexander52]. I also have the granatelli performance boots. The OEM plug boot has a wound spring where as the granatellis are solid/braided connectors. Anyway the truck is hauling ***** again, beautiful idle etc
Did you get these http://www.granatellimotorsports.com...play.php?gid=8 which are listed as being for 04-07 and run about $150?
Old Dec 19, 2007 | 08:42 AM
  #51
Them is the ones
[QUOTE=shs_bulldog]
Yes, my boots were blues though.
It what's inside that counts. I am not sure what I paid for them. Mine came with a plug wire set........RPM outlet is run by idiots IMO. I have COPs and they sent me plug wires......geez. I still have them if anyone is interested.
Old Dec 19, 2007 | 11:48 AM
  #52
jbrew's Avatar
That reminds of Global when they sold the F150 Motorcraft plug and Cop kits.
They would send you the wrong plugs every time
I had to run the plugs up to Murray's and swap them on two separate occasions..
Then I heard others had the same problem , they quit selling the kits soon after ..
BUT - they still have the best COP's on the market..
Old Dec 20, 2007 | 10:37 AM
  #53
Ok, so where is the best place to get a set of Motorcraft plugs and what kinda price should I expect?
Old Dec 23, 2007 | 11:14 PM
  #54
Changed out COP's and Plugs and everything runs great. I agree, it feels like the truck shed 1000 pounds. Only thing is I dummied up and busted an injector cap. Luckily I had one that I had changed out thinking it was causing the missfire. So now where is the best place to get a fuel injector? Advance wants $70 bucks.
Old Dec 23, 2007 | 11:24 PM
  #55
jbrew's Avatar
Didn't you say you had an extra? Why do you need another ?
Well, anyway , I found new type 3's -19lber's for $60 on ebay..
BTW - that price was for all 8
Old Dec 25, 2007 | 07:39 PM
  #56
framescr8pintoy's Avatar
switched out cops, but still having problems
okay so i received my set of global cop's on monday, spent about 2 hrs getting everything switched out. i had already switched out the plugs before i bought all 8 cops, put everything back together with die electric grease. the truck starts better but and drives a little better but still has a shake like its missfiring, also it was shooting out code p0113, come to find out i forgot to plug the iat sensor on the throttle body when i was working... plug it back in disconnected the battery to reset the sel, came back and the light is still on and it still acts like it has a slight misfire. i dont know what else to do now
Old Dec 25, 2007 | 09:19 PM
  #57
Bluegrass's Avatar
Water in the fuel will give you problems. Try 'one' bottle of HEET or simular water absorption additive and give it some time to work.
Old Dec 25, 2007 | 11:38 PM
  #58
jbrew's Avatar
How long was the battery disconnected after you plugged the IAT back in?
Post the code when you get it scanned again - you'll receive help and most likely get it figured out ..
Old Dec 26, 2007 | 12:33 AM
  #59
id say about 20 mins ... havent gotten it scanned yet again got to wait till wednesday when theyre open again
Old Dec 26, 2007 | 02:32 AM
  #60
jbrew's Avatar
Yea , make sure they take the time to see if theres more than one code..
Post the number as you have the last time .. Check your COP plugs - specially #8 , I've forgotten to plug that one in a few times for some reason - Kind of strange you received a cell right after a reboot.. Bluegrass has told me before that one of the first things that gets checked is the EGR System - So check all the Hoses real good. The MAF as well..
If it's a bad Coil (It has happened before, just not as much from the resource you used) hopefully that's the code stored , making it easy . You have a warranty on all Global COP's for 1 year.. You may have to temporarily throw one of the Coils from your old set in to get by - If you call Global and ask for Kevin , he will sent you a replacement right away - 2-3 days..
They'll treat yuh right , but call him for the fastest service..
