engine replacement questions
Old Nov 21, 2007 | 04:34 PM
StangYellow281's Avatar
It appears that my engine S the bed this weekend. No compresion on the passengers side head. Engine will not turn over at all. Im thinking its the timing chain, due to a problem I had where the tensioner pulley CUT into the timing cover.
How much would it cost to replace a timing chain, and where is a good place to get a REMAN engine?
Its a 97f150 4.6L windsor automatic 4wd
Old Nov 21, 2007 | 08:48 PM
jethat's Avatar
If it were me I'd get a used one. if you could find one with under100k on it you would get an engine that should last 150k more and it looks like your truck is a 97. I dont think a reman one would be worth the risk and money. Ford bult them right the first time most of the time.
Old Nov 21, 2007 | 08:49 PM
built54's Avatar
where are you located? i'd build ya one
Old Nov 21, 2007 | 08:53 PM
jbrew's Avatar
That's so true.^^^^
