02 Sensor Install
Old Nov 19, 2007 | 12:55 PM
02SUPRCRUE's Avatar
02 Sensor Install
Looking for advice on how to replace the upstreams on my 02 5.4. I have my new Bosch sensors ready to go but I'm a little concerned about getting to the right side. Any and all advice is appreciated. Yes, I alreadt did the search but didn't find what I was looking for.
Thanks!
02 F150 Super Crew Lariat FX4 White & Silver
5.4 /w Roush Cold Air Intake & K&N filter
3.55 LS
Flowmaster Cat Back
JBA Silver Cat4ward Headers
Rancho RSX's
Rancho Steering Stablizer
Hellwig Rear Anti Sway Bar
Lightning Tails
Outland Sport Bumper Guard
Hella 550's
Silverstars
Superchips 9100 Micro Tuner c/o Troyer Performance
Underdrive Pullies c/o Troyer Performance
Mag-Hytec Trans Pan
Old Nov 19, 2007 | 02:39 PM
Veteran: Army
it's tight but it was pretty easy on my '01. I just used the open side of the wrench fortuantly i didn't have to heat them
Old Nov 19, 2007 | 09:37 PM
torkum's Avatar
Take the wheel and inner fender off for easy access. Use a good penetrating oil and a 22m wrench. I use Sea Foam brand Deep Creep:
Old Nov 19, 2007 | 10:22 PM
jbrew's Avatar
Yep!! A 7/8 open end works too..
Old Nov 19, 2007 | 11:05 PM
scottbigred's Avatar
ya i used a 7/8 open end wrench too. soak them up with some penetrating lube and they should come out. i tried to used that special socket on mine. waste of money. just use an open end wrench and becarefull not to strip them.
Old Nov 20, 2007 | 08:32 AM
02SUPRCRUE's Avatar
Thanks for the replies and advice. This will be my after turkey carving project. One last question, do you need to reset the PCM after changing the 02 sensors?
3.55 LS
Flowmaster Cat Back
Rancho RSX's
Lightning Tails
Hella 550's
Silverstars
Mag-Hytec Trans Pan
Old Nov 20, 2007 | 09:17 AM
jbrew's Avatar
Can't get around it really - the first thing you do before working on it is disconnect the battery
Old Nov 20, 2007 | 01:01 PM
02SUPRCRUE's Avatar
Thanks all Hopefully this goes pretty easy.
3.55 LS
Flowmaster Cat Back
Rancho RSX's
Lightning Tails
Hella 550's
Silverstars
Mag-Hytec Trans Pan
