No Start After Clock Spring Replaced
Old Nov 12, 2007 | 05:50 PM
turbocharged85's Avatar
I replaced the clock spring today. The engine cranks but no start. I removed the ignition switch when I replaced the clock spring. Any ideas, what other information is needed? Any help is appreciated.
Old Nov 12, 2007 | 06:21 PM
Tumba's Avatar
maybe the fuel pump safety switch behind passenger kick panel
check all fuses and fuse links.
Check all grouns.
look for mistakes you may have made inside collom.
that would be the things i check first
Old Nov 12, 2007 | 06:29 PM
If you need schematics let me know if its 2003-2008
Old Nov 12, 2007 | 07:15 PM
It's a 2001 4.6L cruise control.
The only things I unplugged is the clock spring the single wire going to the ignition switch. What is the single wire (blk w/red strip) going to the ignition switch? Somehow I think this wire isn't connected properly.
Old Nov 12, 2007 | 11:48 PM
either primary ignition wire, or PATS wire. I can give you info on 2003 which is more then likely the same stuff.... just shoot me an email
