Rough idol
Old Nov 7, 2007 | 03:31 PM
krazyballer's Avatar
Rough idol
Yea so my truck still has a rough idol. I have changed the fuel filter, the air filter, the plugs,wires,rotor and cap. I cant figure it out i have put in fuel injector cleaner; it only runs rough on idol once u step on the gas it's fine. Any one have any suggestions?
Old Nov 7, 2007 | 04:21 PM
SlammaJamma's Avatar
IAC
kbye
Old Nov 7, 2007 | 04:22 PM
I thought this thread was about Bruce Springstien or Elvis.
Old Nov 7, 2007 | 06:40 PM
2002 wonderboy's Avatar
I thought this thread was about Billy Idol
Check timing as well! Nice day for a white wedding.
Old Nov 7, 2007 | 07:06 PM
Bluegrass's Avatar
I would next look at the vacuum hose to the MAP sensor and all the hoses for that matter.
The MAP has a high influence on fuel.
If it's vaccuum signal is low, it fuels the motor too rich. Or the sensor is faulty.
Old Nov 7, 2007 | 08:05 PM
Cleaned the iac and no luck still shivering. After i put new plug wires it helped alot but still shivering. Any other ideas?
Old Nov 8, 2007 | 03:46 AM
Did you route those new wires exactly as specified? If not, you may get inductive crossfire. Steve83 has a diagram in one of his albums with the proper orientation.
Old Nov 9, 2007 | 06:01 AM
Alright thanks
